你好,
我在客户处实施了一个新环境。 4台主机 - ESXi 6U2,vCenter 6 U2,4x NVidia GRID K2显卡,Cisco Rackserver VMware Horizon View 7,客户端操作系统Windows 10 LTSB x64 测试了最新的官方网格驱动程序,最新的beta驱动程序和cisco主页提供的旧驱动程序。 目前我正在使用354.97驱动程序。 第一个问题 - 安装并激活网格驱动程序后,无法通过vSphere连接到masterdesktop。 您可以看到机器的启动,加载图形驱动程序后屏幕变为空白。 输入正在运行,但您没有看到任何操作。 来自思科的老司机工作正常(但是从2015年初开始,3D性能很差)。 RDP正在从另一个Win10客户端工作,而不是从Win7工作(参见第二个问题) 第二个问题 当我尝试从任何Windows 7客户端RDP进入机器时,我可以输入我的凭据,并在点击连接后立即显示错误“无法连接到桌面”。 当我尝试从Win10客户端连接时,一切都很好没有错误。 任何计算机上都没有事件日志。 有什么提示吗? 谢谢 塞巴斯蒂安 以上来自于谷歌翻译 以下为原文 Hi there, I've implemented a new environment at a customer. 4 Hosts - ESXi 6U2, vCenter 6 U2, 4x NVidia GRID K2 graphics card, Cisco Rackserver VMware Horizon View 7, Client OS Windows 10 LTSB x64 Tested latest official Grid driver, latest beta driver and an old driver provided from cisco homepage. At the moment I'm using 354.97 driver. First problem - after installing and activating the Grid Driver it's not possible to connect to the masterdesktop through vSphere. You can see the boot of the machine and after loading graphics driver the screen goes blank. Inputs are working but you don't see anything you do. The old driver from cisco works fine (but it's from early 2015 and have a poor 3D performance). RDP is working from another Win10 client, not from Win7 (see second problem) Second problem When I try to RDP into the machine from any Windows 7 client I can type in my credentials and after clicking connect immidiatly the error "can't connect to the desktop" appears. When I try to connect from Win10 client everything is fine without an error. There are no eventlogs on any machine. Any hints for me? Thanks Sebastian |
2个回答
这是预期的行为。
不支持通过vCenter控制台访问访问支持GPU的VM。 您应该使用Horizon Direct连接或备用远程访问协议。 RDP忽略了GPU,因此这表明存在另一个问题。 此外,请确保您在ESX主机中使用352.97 vGPU Manager .vib,因为它与Guest驱动程序匹配,并且您在Host和Guest中都拥有正确的版本。 以上来自于谷歌翻译 以下为原文 This is expected behaviour. Accessing a GPU enabled VM via vCenter console access is not supported. You should use Horizon Direct connect or an alternative remote access protocol. RDP ignores the GPU, so this suggests there is another issue present. Also, ensure that you're using the 352.97 vGPU Manager .vib in the ESX host as this is matched to the Guest driver and you have you have the correct versions in both Host and Guest. |
好的,很高兴知道。
在Cisco提供的旧驱动程序中工作。 所以我对此感到有些困惑。 好的,然后客户使用Horizon Direct Connect来管理机器。 驱动程序使用最新的软件包,相同的主机版本和来宾VM内部。 我认为这与Windows 7有关,当Horizon Direct连接正常工作时,不需要对机器进行RDP。 非常感谢你。 塞巴斯蒂安 以上来自于谷歌翻译 以下为原文 Ok, good to know. In the old Driver provided by Cisco works. So I've been a little bit confused about that. Ok, then the customer use Horizon Direct Connect for administering the machine. Drivers are used from the latest package, same Version on Host and inside the guest VM. I think it's related to Windows 7 and when Horizon Direct connect is working there is no need for RDPing into the machine. Thank you very much. Sebastian |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
2835 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3227 浏览 4 评论
GMT+8, 2024-4-26 09:31 , Processed in 0.568600 second(s), Total 72, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
