哪种方式获取数据/文件(例如,大小约为3Gb)到LPA软件更快:M9505A框架 - >通过AXIe背板 - >到M9536A AXIe嵌入式控制器运行LPA软件或M9505A框架 - >通过M9048A(B)PCIe
适配器 - >运行LPA软件的外部PC? 您能比较一下最大通信速度(或更好的实际测量)吗? 谢谢! 以上来自于谷歌翻译 以下为原文 which way to get data/file (for example, size is about 3Gb) to LPA software is faster: M9505A frame -> by AXIe backplane -> to M9536A AXIe embedded controller running LPA software or M9505A frame -> by M9048A(B) PCIe adapter -> to external PC running LPA software ? Could you please compare max communication speed (or better practical measurements) ? Thanks! |
4个回答
你的旅费可能会改变。
但是,严重的是,由于与EC和通过电缆连接到PC的连接都是Gen2 x8,这更多地依赖于另一端的PC(EC与你的相比),而不是其他任何东西。 我假设你试图将数据卸载到一个文件进行存储,在这种情况下你可能想要使用COM编程连接,而且,这将依赖于PC。 人 以上来自于谷歌翻译 以下为原文 Your mileage may vary. Seriously, though, since the connection to the EC and via the cable to a PC are both Gen2 x8, this is much more dependent on the PC at the other end (EC vs. yours), than anything else. I assume that you are trying to offload the data to a file for storage, in which case you'll probably want to use the COM programming connection, and, again, this will be PC dependent. Al |
nvywyerwer 发表于 2018-9-20 16:56 仍有一些误解,因为M9536A数据表(5990-7756EN)提到“Gen 2 x4 PCIe链接到AXIe背板提供2 GB / s最大数据带宽”。 “M9048A是一款PCIe接口卡,适用于带有PCIe扩展插槽的计算机。它提供从外部计算机到AXIe机箱的极高性能链接,例如M9502A / 5A或PCIe电缆接口,如M9021A。 Gen 2 x8 PCIe电缆链路,速度高达4GB / s。这意味着可以使用台式机或机架式计算机构建高性能系统。 对我来说,当U4164A / U4154B LA卡数据卸载到LPA应用程序时,看起来配备M9048A PCIe卡的外置PC(足够快)提供的性能比M9536A高2倍。 以上来自于谷歌翻译 以下为原文 There is still some misunderstanding, as M9536A datasheet (5990-7756EN) mention "Gen 2 x4 PCIe link to AXIe backplane providing 2 GB/s max data bandwidth". "The M9048A is a PCIe interface card for computers with PCIe expansion slots. It provides an extremely high performance link from an external computer to an AXIe Chassis, such as the M9502A/5A or a PCIe Cable Interface such as the M9021A. The card has Gen 2 x8 PCIe cable link capable of achieving speeds up to 4GB/s. This means a high performance system can be built using desktop or rack-mounted computers". For me, it looks like external PC (fast enough) equipped with M9048A PCIe card provides better about 2-times performance than M9536A when U4164A/U4154B LA card data is off-loaded to LPA application sw ???? |
毛新宇的儿子王大锤 发表于 2018-9-20 17:10 从理论上讲,是的......实际上,SW的性能会淹没链接中的任何性能差异。 人 以上来自于谷歌翻译 以下为原文 In theory, yes... In reality, the performance of the SW will drown any performance differences in the link. Al |
我刚送了一个PM。 人 以上来自于谷歌翻译 以下为原文 I just sent a PM. Al |
只有小组成员才能发言,加入小组>>
2108 浏览 1 评论
1870 浏览 1 评论
1725 浏览 5 评论
2594 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1568 浏览 4 评论
512浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
369浏览 0评论
1429浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
282浏览 0评论
2264浏览 0评论
GMT+8, 2024-5-9 10:29 , Processed in 1.236006 second(s), Total 83, Slave 67 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
