我们有一个项目,与cy8c5666axi-lp001 PSoC芯片产生的5lp。由于有限的可用性在生产的时候,我们不得不与cy8c5666axi-lp004 5lp芯片在板。2芯片实际上是相同的,除了cy8c5666axi-lp004有USB选项。
我们能够更新固件上板(与cy8c5666axi-lp004芯片)通过PSoC Creator,但利用PSoC的程序员时,它不会闪光和抱怨的HEX文件不适用于此(cy8c5666axi-lp004)芯片。为什么PSoC Creator工作而不是PSoC程序员? 以上来自于百度翻译 以下为原文 We have a project that was created with the CY8C5666AXI-LP001 PSoC 5LP chip. Due to limited availability at the time of production, we had to populate our boards with the CY8C5666AXI-LP004 5LP chip. The 2 chips are practically identical, except the CY8C5666AXI-LP004 has USB option. We're able to flash the firmware onto the board (with the CY8C5666AXI-LP004 chip) via PSoC Creator, but when using PSoC Programmer, it won't flash and complains that the hex file is not intended for this (CY8C5666AXI-LP004) chip. Why does PSoC Creator work and not PSoC Programmer? |
1个回答
PSoC Creator可以巧妙地检测你的设备是否与项目兼容,即使它与你连接的芯片不完全相同。这通常适用于具有几乎相同设计并且属于特定系列类的芯片。这不是PSoC程序员的情况,因为它要求芯片与HEX文件中的芯片完全一样。PSoC Creator说,如果你有一个不同的目标,而不是你的项目中的一个不同的目标之前,你的程序如下
这只是PSoC Creator的一个特性,帮助开发人员测试较小的闪存大小MCU和属于同一个家庭的较大的闪存大小。因此,在MPN中最后一个数字并不严格。 只需在C造造器上构建CY8C5666 AXI-LP04的项目,然后使用PSoC程序员编写HEX文件。它会起作用的。 当做, 德黑拉杰 以上来自于百度翻译 以下为原文 PSoC Creator can smartly detect if your device is compatible with the project even though it isn't exactly the same chip you have connected. This generally applies to chips which have almost identical designs and belong to a particular series class. This isn't the case with PSoC Programmer because it requires the chip to be exactly the same as the one in the HEX file. PSoC Creator says this before you program as higlighted below if you have a different target other than the one in your project: This is just a feature of PSoC Creator to help developers to test with smaller flash size MCUs and larger ones belonging to the same family. So it isn't stringent upto the last digit in MPN. Just build the project for CY8C5666AXI-LP004 in Creator and then program the HEX file using PSoC Programmer. It will work. Regards, Dheeraj |
只有小组成员才能发言,加入小组>>
717个成员聚集在这个小组
加入小组1909 浏览 1 评论
1662 浏览 1 评论
3418 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1579 浏览 6 评论
1387 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
205浏览 2评论
193浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
334浏览 2评论
361浏览 1评论
71浏览 1评论
GMT+8, 2024-5-8 01:15 , Processed in 0.744594 second(s), Total 77, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
