我有一个定制的板使用cyble-212019-00 proc模块连接到一对夫妇的传感器使用SPI传输稳定。董事会通过电缆连接到编程和调试cy8ckit-042-ble(引脚0.6-0.7之间为SWD XRES,3.3V和地面连接。)硬件的编程和调试工作;下一步是尝试深度睡眠模式。
经过一些工作,并使用代码类似于an92584在、我可以去深睡眠而连接调试器。BLE作品。平均电流与SPI和ADC关闭约1.8 Ma在调试模式。允许约1.5 Ma的调试器(从其他来源)这说我画了几百微安,这是现在。 问题是,当我尝试断开调试器(设置串口线调试引脚GPIO),而不是目前的下降,增加了波动在6到10 mA的范围内。 我曾规划在释放模式,以及给我的板完全分别用3.3V到董事会。同样的波动大电流。 做XRES或SWD引脚需要拉到一定的水平? 我正在使用PSoC创建者4.1更新1。 谢谢你的建议。 兰迪 以上来自于百度翻译 以下为原文 I have a custom board using a CYBLE-212019-00 PRoC module connected to a couple of sensors using SPI and transmitting over BLE. The board is connected through a custom cable to the CY8CKIT-042-BLE for programming and debugging (pins 0.6 and 0.7 for SWD, Xres, 3.3V, and ground are connected.) The hardware all works for programming and debugging; next step was to try deep sleep mode. After some work, and using code similar to AN92584 on BLE, I can get it to go to deep sleep while connected to the debugger. BLE works. Average current with SPI and ADC shut down is about 1.8 mA in debug mode. Allowing for about 1.5 mA for debugger (from other sources) this says I am drawing a few hundred uA, which is okay for now. Problem is, when I try to disconnect the debugger (set the serial wire debugger pins to GPIO), instead of the current dropping, it increases and fluctuates in the 6 to 10 mA range. I have tried programming in Release mode, and powering my board completely separately with just 3.3V to the board. Still same fluctuating high current. Do Xres or the SWD pins need to be pulled to a certain level? I am using PSoC Creator 4.1 Update 1. Thanks for any suggestions. Randy |
3个回答
嗨,兰迪,
您的意思是您已经将串行调试器引脚设置为GPIO?CyDWR? SWD电缆也断开了吗? 谢谢, 赖安 以上来自于百度翻译 以下为原文 Hi Randy, Do you mean you have set the serial debugger pins to GPIO in .cydwr? Did the SWD cable disconnected too? Thanks, Ryan |
嗨,赖安, 是的,in .CydWr& Gt;系统选项卡& gt;编程/调试& gt;调试选择被设置为GPIO。 并曾与SWD电缆断开,所以SWD引脚和XRES是浮动的,只有3.3V和地面连接… 以上来自于百度翻译 以下为原文 Hi Ryan, Yes, in .cydwr > system tab > programming/debugging > debug select is set to GPIO. And have tried with SWD cable disconnected, so SWD pins and XRES are floating, and only 3.3V and ground are connected... |
竹马还巢 发表于 2018-8-28 12:10 嗨,兰迪, 因此,在这种情况下,我认为额外的功耗可能不是由XRES和SWD引起的。 谢谢, 赖安 以上来自于百度翻译 以下为原文 Hi Randy, So in this case, I guess the extra power consumption may not be caused by XRES and SWD. Thanks, Ryan |
只有小组成员才能发言,加入小组>>
717个成员聚集在这个小组
加入小组1903 浏览 1 评论
1654 浏览 1 评论
3409 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1570 浏览 6 评论
1382 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
190浏览 2评论
184浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
325浏览 2评论
352浏览 1评论
63浏览 1评论
GMT+8, 2024-4-26 19:20 , Processed in 0.673283 second(s), Total 68, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
