哈哈,你太幸运了,我之前刚刚拿到一份TI DESIGN的文档。
就是用129设计的以太网转UART的设计。 Serial communications (RS-232/422/485) have traditionally been used in industrial automation to connect various instruments such as sensors and data loggers to stand alone monitoring stations such as computers. The limitations of serial communications, such as distance, accessibility, and the amount of data transferred at any one time and speed, has led to a demand for a more flexible means of communicating. When a legacy product contains only a serial port for a configuration or control interface, continuing to access the legacy product through the serial interface can become challenging over time. Newer computers, especially laptops, do not necessarily have serial ports, and a serial connection is limited by cable length (typically 10 m). Using Ethernet in place of the serial port provides many benefits. Although slow to catch up with IT infrastructure in commercial environments, Ethernet is increasingly regarded as the defacto standard of communications in industrial markets. However, the sheer volume of existing serial-based products and the low cost and ease of integrating these ‘legacy’ protocols means that serial communication is strong in many areas of industry. Due to the minimal processing power required, the ruggedness and reliability of connectors, even relatively new products such as GPS receivers continue to adopt RS-232 and RS-485. RS-485 has been the PHY protocol for industrial networks since Modbus was launched by Modicon in the 1970s. Other manufacturers followed Modicon and used protocols such as PROFIBUS DP and INTERBUS. Contemporary systems are Ethernet-based to allow individual "islands of automation" to share data captured throughout the plant and the company, "top floor to shop floor", and in some cases, the world. To enable legacy serial based hardware to take advantage of Ethernet, Serial-to-Ethernet device converters were designed. Ethernet is a more common interface available on computing equipment today: • The legacy product can be shared more easily (instead of changing a cable connection, a new connection over the existing network is made). • 10-m cable length is no longer an issue (subject to tolerance of the increased transmission delay if the two pieces of equipment are separated by several routers or are located on a heavily loaded network segment). 详细的资料如以下设计文档: Michael Qian |
只有小组成员才能发言,加入小组>>
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
1909 浏览 0 评论
TPS55340通电后输入端保险丝烧断,芯片输入和GND之间短路
3666 浏览 4 评论
5040 浏览 0 评论
请问如何用DM368对RGB格式的图片数据进行编码生成JPEG格式图片?
1739 浏览 1 评论
9423 浏览 8 评论
CC3100BOOST使用CC3200lunchXL进行烧录
681浏览 2评论
729浏览 1评论
TMS320F28034: 利用C2prog通过SCI给TMS320F28034烧录程序,出现错误提示:Bootloading... failed (invalid echo)!
697浏览 1评论
求DLPC350 Programmer’s Guide User's Guide 中文版说明书
1207浏览 1评论
1793浏览 1评论
GMT+8, 2024-5-10 14:57 , Processed in 0.653761 second(s), Total 52, Slave 46 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
