扫一扫,分享给好友
各位技术支持:
我这里遇到一个问题:打印信息如下: Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 4.9.28-geed43d1050 (linux@ubuntu) (gcc version 6.2.1 20161016 (Linaro GCC 6.2-2016.11) ) #10 PREEMPT Mon Sep 4 08:00:15 PDT 2017 [ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] OF: fdt:Machine model: TI AM335x EVM-SK [ 0.000000] efi: Getting EFI parameters from FDT: [ 0.000000] efi: UEFI not found. [ 0.000000] cma: Reserved 48 MiB at 0x8a800000 [ 0.000000] Memory policy: Data cache writeback [ 0.000000] CPU: All CPU(s) started in SVC mode. [ 0.000000] AM335X ES2.1 (sgx neon) [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 64960 [ 0.000000] Kernel command line: console=ttyO0,115200 ip=192.168.1.199:192.168.175:192.168.1.1:255.255.255.0::eth0:off root=/dev/nfs rw nfsroot=192.168.1.175:/source/rootfs [ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes) [ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes) [ 0.000000] Memory: 198324K/262144K available (7168K kernel code, 279K rwdata, 2348K rodata, 1024K init, 272K bss, 14668K reserved, 49152K cma-reserved, 0K highmem) [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB) [ 0.000000] vmalloc : 0xd0800000 - 0xff800000 ( 752 MB) [ 0.000000] lowmem : 0xc0000000 - 0xd0000000 ( 256 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc0800000 (8160 kB) [ 0.000000] .init : 0xc0b00000 - 0xc0c00000 (1024 kB) [ 0.000000] .data : 0xc0c00000 - 0xc0c45f10 ( 280 kB) [ 0.000000] .bss : 0xc0c45f10 - 0xc0c8a1b4 ( 273 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] Build-time adjustment of leaf fanout to 32. [ 0.000000] NR_IRQS:16 nr_irqs:16 16 [ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts [ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz [ 0.000014] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns [ 0.000033] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns [ 0.000043] OMAP clocksource: timer1 at 24000000 Hz [ 0.000203] clocksource_probe: no matching clocksources found [ 0.000370] Console: colour dummy device 80x30 [ 0.000396] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0' [ 0.000402] This ensures that you still see kernel messages. Please [ 0.000407] update your kernel commandline. [ 0.000429] Calibrating delay loop... 996.14 BogoMIPS (lpj=4980736) [ 0.089222] pid_max: default: 32768 minimum: 301 [ 0.089343] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.089353] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.090098] CPU: Testing write buffer coherency: ok [ 0.090476] Setting up static identity map for 0x80100000 - 0x80100060 [ 0.091265] EFI services will not be available. [ 0.092417] devtmpfs: initialized [ 0.103141] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3 [ 0.103463] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [ 0.103488] futex hash table entries: 256 (order: -1, 3072 bytes) [ 0.106981] pinctrl core: initialized pinctrl subsystem [ 0.108182] NET: Registered protocol family 16 [ 0.110100] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.123264] omap_hwmod: debugss: _wait_target_disable failed [ 0.199213] cpuidle: using governor ladder [ 0.229201] cpuidle: using governor menu [ 0.234658] OMAP GPIO hardware version 0.1 [ 0.248924] hw-breakpoint: debug architecture 0x4 unsupported. [ 0.286523] edma 49000000.edma: TI EDMA DMA engine driver [ 0.287364] reg-fixed-voltage fixedregulator2: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_wl12xx_gpio, deferring probe [ 0.290415] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c0_pins, deferring probe [ 0.290563] media: Linux media interface: v0.10 [ 0.290615] Linux video capture interface: v2.00 [ 0.290655] pps_core: LinuxPPS API ver. 1 registered [ 0.290661] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti [ 0.290684] PTP clock support registered [ 0.290719] EDAC MC: Ver: 3.0.0 [ 0.291744] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400 [ 0.292065] Advanced Linux Sound Architecture Driver Initialized. [ 0.293197] clocksource: Switched to clocksource timer1 [ 0.302499] NET: Registered protocol family 2 [ 0.303297] TCP established hash table entries: 2048 (order: 1, 8192 bytes) [ 0.303329] TCP bind hash table entries: 2048 (order: 1, 8192 bytes) [ 0.303355] TCP: Hash tables configured (established 2048 bind 2048) [ 0.303427] UDP hash table entries: 256 (order: 0, 4096 bytes) [ 0.303444] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) [ 0.303574] NET: Registered protocol family 1 [ 0.303998] RPC: Registered named UNIX socket transport module. [ 0.304011] RPC: Registered udp transport module. [ 0.304017] RPC: Registered tcp transport module. [ 0.304022] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.304924] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available [ 0.307092] workingset: timestamp_bits=14 max_order=16 bucket_order=2 [ 0.314037] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.314912] NFS: Registering the id_resolver key type [ 0.314957] Key type id_resolver registered [ 0.314964] Key type id_legacy registered [ 0.315006] ntfs: driver 2.1.32 [Flags: R/O]. [ 0.316779] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) [ 0.316799] io scheduler noop registered [ 0.316806] io scheduler deadline registered [ 0.316948] io scheduler cfq registered (default) [ 0.317834] pinctrl-single 44e10800.pinmux: please update dts to use #pinctrl-cells = <1> [ 0.318283] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568 [ 0.321174] backlight supply power not found, using dummy regulator [ 0.375183] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled [ 0.378869] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 158, base_baud = 3000000) is a 8250 [ 0.990946] console [ttyS0] enabled [ 0.996212] omap_rng 48310000.rng: OMAP Random Number Generator ver. 20 [ 1.002990] [drm] Initialized [ 1.007041] panel panel: found backlight [ 1.011867] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 1.018592] [drm] No driver support for vblank timestamp query. [ 1.047957] Console: switching to colour frame buffer device 60x34 [ 1.055874] tilcdc 4830e000.lcdc: fb0: frame buffer device [ 1.096217] brd: module loaded [ 1.105508] loop: module loaded [ 1.110832] libphy: Fixed MDIO Bus: probed [ 1.183235] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6 [ 1.189400] davinci_mdio 4a101000.mdio: detected phy mask fffffffc [ 1.196935] libphy: 4a101000.mdio: probed [ 1.200977] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver Atheros 8031 ethernet [ 1.210358] davinci_mdio 4a101000.mdio: phy[1]: device 4a101000.mdio:01, driver Atheros 8031 ethernet [ 1.220371] cpsw 4a100000.ethernet: Detected MACID = c4:ed:ba:8b:76:95 [ 1.227302] cpsw 4a100000.ethernet: cpts: overflow check period 500 (jiffies) [ 1.235610] cpsw 4a100000.ethernet: cpsw: Detected MACID = c4:ed:ba:8b:76:97 [ 1.244181] mousedev: PS/2 mouse device common for all mice [ 1.250126] i2c /dev entries driver [ 1.255410] cpuidle: enable-method property 'ti,am3352' found operations [ 1.263119] omap_hsmmc 48060000.mmc: Got CD GPIO [ 1.324625] ledtrig-cpu: registered to indicate activity on CPUs [ 1.333650] NET: Registered protocol family 10 [ 1.339505] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver [ 1.346339] NET: Registered protocol family 17 [ 1.351194] Key type dns_resolver registered [ 1.355814] omap_voltage_late_init: Voltage driver support not added [ 1.393407] tps65910 0-002d: No interrupt support, no core IRQ [ 1.401154] vrtc: supplied by vbat [ 1.408333] vio: supplied by vbat [ 1.413117] vdd1: supplied by vbat [ 1.418347] vdd2: supplied by vbat [ 1.423208] random: fast init done [ 1.428268] vdig1: supplied by vbat [ 1.433088] vdig2: supplied by vbat [ 1.437963] vpll: supplied by vbat [ 1.442695] vdac: supplied by vbat [ 1.447504] vaux1: supplied by vbat [ 1.452332] vaux2: supplied by vbat [ 1.457232] vaux33: supplied by vbat [ 1.462159] vmmc: supplied by vbat [ 1.466927] vbb: supplied by vbat [ 1.471744] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz [ 1.479163] omap_hsmmc 48060000.mmc: Got CD GPIO [ 1.652695] mmc0: host does not support reading read-only switch, assuming write-enable [ 1.664079] mmc0: new high speed SDHC card at address aaaa [ 1.670535] mmcblk0: mmc0:aaaa SU04G 3.69 GiB [ 1.676997] mmcblk0: p1 p2 p3 [ 1.695078] input: gpio_buttons0 as /devices/platform/gpio_buttons0/input/input0 [ 1.706413] hctosys: unable to open rtc device (rtc0) [ 1.726390] net eth0: initializing cpsw version 1.12 (0) [ 1.731814] net eth0: initialized cpsw ale version 1.4 [ 1.737139] net eth0: ALE Table size 1024 [ 1.844174] Atheros 8031 ethernet 4a101000.mdio:00: attached PHY driver [Atheros 8031 ethernet] (mii_bus:phy_addr=4a101000.mdio:00, irq=-1) [ 1.864648] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [ 3.924399] cpsw 4a100000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx [ 3.933330] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [ 3.963291] IP-Config: Complete: [ 3.966576] device=eth0, hwaddr=c4:ed:ba:8b:76:95, ipaddr=192.168.1.199, mask=255.255.255.0, gw=192.168.1.1 [ 3.977225] host=192.168.1.199, domain=, nis-domain=(none) [ 3.983258] bootserver=192.168.175.0, rootserver=192.168.1.175, rootpath= [ 3.991320] lis3_reg: disabling [ 3.994680] vwl1271: disabling [ 3.998146] ALSA device list: [ 4.001150] No soundcards found. [ 4.151278] VFS: Mounted root (nfs filesystem) on device 0:15. [ 4.158288] devtmpfs: mounted [ 4.165400] Freeing unused kernel memory: 1024K (c0b00000 - c0c00000) [ 4.924685] systemd[1]: System time before build time, advancing clock. [ 5.073952] systemd[1]: Configuration file /etc/systemd/system.conf is marked executable. Please remove executable permission bits. Proceeding anyway. [ 5.087718] systemd[1]: Configuration file /etc/systemd/system.conf is marked world-writable. Please remove world writability permission bits. Proceeding anyway. [ 5.135585] systemd[1]: systemd 230 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN) [ 5.154709] systemd[1]: Detected architecture arm. Welcome to Arago 2017.05! [ 5.196152] systemd[1]: Set hostname to [ 5.773458] systemd[1]: Configuration file /lib/systemd/system/remote-fs.target is marked executable. Please remove executable permission bits. Proceeding anyway. [ 5.789063] systemd[1]: Configuration file /lib/systemd/system/remote-fs.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway. [ 5.818162] systemd[1]: Configuration file /lib/systemd/system/shutdown.target is marked executable. Please remove executable permission bits. Proceeding anyway. [ 5.832912] systemd[1]: Configuration file /lib/systemd/system/shutdown.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway. [ 5.851449] systemd[1]: Configuration file /lib/systemd/system/remote-fs-pre.target is marked executable. Please remove executable permission bits. Proceeding anyway. [ 5.866615] systemd[1]: Configuration file /lib/systemd/system/remote-fs-pre.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway. [ 5.887289] systemd[1]: Configuration file /lib/systemd/system/-.slice is marked executable. Please remove executable permission bits. Proceeding anyway. [ SKIP ] Ordering cycle found, skipping alignment.service [ OK ] Listening on /dev/initctl Compatibility Named Pipe. [ OK ] Created slice User and Session Slice. [ OK ] Reached target Swap. [ OK ] Listening on Journal Socket. [ OK ] Listening on udev Kernel Socket. [ OK ] Started Dispatch Password Requests to Console Directory Watch. [ OK ] Created slice System Slice. [ OK ] Created slice system-serialx2dgetty.slice. Starting Remount Root and Kernel File Systems... Starting Load Kernel Modules... [ OK ] Created slice system-getty.slice. Mounting Debug File System... Mounting Temporary Directory... [ OK ] Reached target Slices. [ OK ] Started Forward Password Requests to Wall Directory Watch. [ OK ] Reached target Paths. [ 7.066330] cryptodev: loading out-of-tree module taints kernel. [ 7.081488] cryptodev: driver 1.8 loaded. Mounting POSIX Message Queue File System... [ OK ] Listening on Syslog Socket. [ OK ] Listening on Network Service Netlink Socket. Starting Create Static Device Nodes in /dev... [ OK ] Reached target Remote File Systems. [ OK ] Listening on Journal Socket (/dev/log). Starting Setup Virtual Console... Starting Journal Service... [ OK ] Listening on udev Control Socket. [ OK ] Mounted Debug File System. [ OK ] Mounted POSIX Message Queue File System. [ OK ] Mounted Temporary Directory. [ 7.579193] systemd-journald[101]: Configuration file /etc/systemd/journald.conf is marked executable. Please remove executable permission bits. Proceeding anyway. [ OK ] Started Remount Root and Kernel File Systems.[ 7.600908] systemd-journald[101]: Configuration file /etc/systemd/journald.conf is marked world-writable. Please remove world writability permission bits. Proceeding anyway. [ OK ] Started Load Kernel Modules. [ OK ] Started Setup Virtual Console. [ OK ] Started Create Static Device Nodes in /dev. Starting udev Kernel Device Manager... Mounting Configuration File System... Starting Apply Kernel Variables... [ OK ] Reached target Local File Systems (Pre). Mounting /media/ram... Mounting /var/volatile... Starting udev Coldplug all Devices... [ 8.070517] random: crng init done [ OK ] Mounted Configuration File System. [ OK ] Mounted /var/volatile. [ OK ] Mounted /media/ram. [ OK ] Started Journal Service. [ OK ] Started Apply Kernel Variables. Starting Flush Journal to Persistent Storage... Starting Load/Save Random Seed... [ OK ] Reached target Local File Systems. [ OK ] Started udev Kernel Device Manager. [ OK ] Started Load/Save Random Seed. [ 8.675549] systemd-journald[101]: Received request to flush runtime journal from PID 1 [ OK ] Started Flush Journal to Persistent Storage. Starting Create Volatile Files and Directories... [ OK ] Started Create Volatile Files and Directories. Starting Update UTMP about System Boot/Shutdown... Starting Network Time Synchronization... [ OK ] Started Update UTMP about System Boot/Shutdown. [ OK ] Started Network Time Synchronization. Starting Synchronize System and HW clocks... [ OK ] Reached target System Time Synchronized. [FAILED] Failed to start Synchronize System and HW clocks. See 'systemctl status sync-clocks.service' for details. [ OK ] Created slice system-systemdx2dbacklight.slice. [ 10.580193] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec Starting Load/Save Screen Backlight...htness of backlight:backlight... [ OK ] Found device /dev/ttyS0. [ OK ] Started udev Coldplug all Devices. [ 10.770731] omap_rtc 44e3e000.rtc: already running [ 10.830973] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0 [ OK ] Started Load/Save Screen Backlight Brightness of backlight:backlight. [ OK ] Reached target System Initialization. [ OK ] Started Daily Cleanup of Temporary Directories. [ OK ] Reached target Timers. [ OK ] Listening on RPCBind Server Activation Socket. [ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket. [ OK ] Listening on D-Bus System Message Bus Socket. [ OK ] Listening on dropbear.socket. [ OK ] Reached target Sockets. [ OK ] Reached target Basic System. [ OK ] Started System Logging Service. Starting Telephony service... Starting uim-sysfs.service... Starting Avahi mDNS/DNS-SD Stack... [ OK ] Started D-Bus System Message Bus. [ 12.126716] omap-sham 53100000.sham: hw accel on OMAP rev 4.3 [ 12.263682] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2 [ 12.379929] omap-aes 53500000.aes: will run requests pump with realtime priority [ 12.560413] [drm] Initialized pvr 1.14.3699939 20110701 on minor 1 [ 12.734696] remoteproc remoteproc0: wkup_m3 is available [ 12.741438] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle [ 12.764585] PM: Cannot get wkup_m3_ipc handle [ 13.017427] PM: Cannot get wkup_m3_ipc handle [ 13.022266] remoteproc remoteproc0: powering up wkup_m3 [ 13.246392] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 224344 [ 13.281784] asoc-simple-card sound: tlv320aic3x-hifi <-> 4803c000.mcasp mapping ok [ 13.309966] PM: Cannot get wkup_m3_ipc handle [ 13.458124] remoteproc remoteproc0: remote processor wkup_m3 is now up [ 13.458148] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x192 [ OK ] Started Avahi mDNS/DNS-SD Stack. [ OK ] Started Telephony service. Starting Network Service... [ 14.551246] Bluetooth: Core ver 2.22 [ 14.660555] NET: Registered protocol family 31 Starting Login Service... Starting Print notice about GPLv3 packages... [ 14.775019] Bluetooth: HCI device and connection manager initialized [ OK ] Started Kernel Logging Service. [ 14.916245] Bluetooth: HCI socket layer initialized [ 15.029733] Bluetooth: L2CAP socket layer initialized [ 15.170756] Bluetooth: SCO socket layer initialized [ OK ] Found device /dev/ttyS3. [ OK ] Started Network Service. [ 17.100740] EXT4-fs (mmcblk0p3): mounting ext3 file system using the ext4 subsystem [ 17.123759] EXT4-fs (mmcblk0p2): mounting ext3 file system using the ext4 subsystem [ 17.185425] EXT4-fs (mmcblk0p2): warning: maximal mount count reached, running e2fsck is recommended [ 17.188347] EXT4-fs (mmcblk0p2): recovery complete [ 17.188370] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null) [ 17.537682] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck. [ 17.898512] EXT4-fs (mmcblk0p3): warning: maximal mount count reached, running e2fsck is recommended [ 18.035534] EXT4-fs (mmcblk0p3): recovery complete [ 18.104397] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null) [ OK ] Found device /dev/mmcblk0p1. [ OK ] Started Login Service. [ 21.859266] TI-am335x-tsc TI-am335x-tsc: ti,charge-delay not specified [ 21.944514] input: ti-tsc as /devices/platform/ocp/44e0d000.tscadc/TI-am335x-tsc/input/input1 [ 22.045188] PM: bootloader does not support rtc-only! [ 23.385424] 47401300.u***-phy supply vcc not found, using dummy regulator [ 23.512971] 47401b00.u***-phy supply vcc not found, using dummy regulator [ 23.535392] u***core: registered new interface driver u***fs [ 23.535458] u***core: registered new interface driver hub [ 23.535755] u***core: registered new device driver u*** [ 23.884305] mu***-hdrc mu***-hdrc.0: MUSB HDRC host driver [ 23.889699] mu***-hdrc mu***-hdrc.0: new USB bus registered, assigned bus number 1 [ 24.055325] ti-pruss 4a300000.pruss: creating PRU cores and other child platform devices [ 24.056864] irq: no irq domain found for /ocp/pruss_soc_bus@4a326000/pruss@4a300000/intc@4a320000 ! [ 24.087943] irq: no irq domain found for /ocp/pruss_soc_bus@4a326000/pruss@4a300000/intc@4a320000 ! [ 24.402004] hub 1-0:1.0: USB hub found [ 24.459767] hub 1-0:1.0: 1 port detected [ 24.625879] mu***-hdrc mu***-hdrc.1: MUSB HDRC host driver [ 24.631269] mu***-hdrc mu***-hdrc.1: new USB bus registered, assigned bus number 2 [ 24.675372] remoteproc remoteproc1: 4a334000.pru0 is available [ 24.675468] pru-rproc 4a334000.pru0: PRU rproc node /ocp/pruss_soc_bus@4a326000/pruss@4a300000/pru@4a334000 probed successfully [ 24.693553] remoteproc remoteproc2: 4a338000.pru1 is available [ 24.693635] pru-rproc 4a338000.pru1: PRU rproc node /ocp/pruss_soc_bus@4a326000/pruss@4a300000/pru@4a338000 probed successfully [ 25.041666] hub 2-0:1.0: USB hub found [ 25.067945] hub 2-0:1.0: 1 port detected [ OK ] Started uim-sysfs.service. *************************************************************** *************************************************************** NOTICE: This file system contains the following GPLv3 packages: autoconf binutils cpp-symlinks cpp dosfstools g++-symlinks g++ gawk-dev gawk gcc-symlinks gcc gdb gdbserver gstreamer1.0-libav hidapi libcairo-perf-utils libgmp10 libidn11 libmpc3 libmpfr4 libreadline-dev libreadline6 m4-dev m4 make nettle swig-dev swig If you do not wish to distribute GPLv3 components please remove the above packages prior to distribution. This can be done using the opkg remove command. i.e.: opkg remove Where NOTE: If the package is a dependency of another package you will be notified of the dependent packages. You should use the --force-removal-of-dependent-packages option to also remove the dependent packages as well *************************************************************** *************************************************************** [ OK ] Started Print notice about GPLv3 packages. [ OK ] Reached target Sound Card. Starting rc.pvr.service... Starting Start USB gadget... [ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch. [ OK ] Reached target Network. Starting Network Name Resolution... [ OK ] Started strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf. Starting Enable and configure wl18xx bluetooth stack... [ 31.327331] PVR_K: UM DDK-(3699939) and KM DDK-(3699939) match. [ OK ] Starting Lightning Fast Webserver With Light System Requirements... Starting Simple Network Management Protocol (SNMP) Daemon.... Starting Permit User Sessions... [ 31.744256] using random self ethernet address [ 31.791452] using random host ethernet address [ OK ] [ 31.855990] using host ethernet address: C4:ED:BA:8B:76:97Started Permit User Sessions. [ 31.924254] using random self ethernet address [ 31.924260] using random host ethernet address [ 31.924275] using host ethernet address: C4:ED:BA:8B:76:97 [ 31.936687] u***0: HOST MAC c4:ed:ba:8b:76:97 [ 31.937384] u***0: MAC f6:64:bb:d8:26:d8 [ OK ] Started Getty on tty1. [ 32.302171] Mass Storage Function, version: 2009/09/11 [ 32.331421] LUN: removable file: (no medium) [ 32.344318] LUN: removable read only file: /dev/mmcblk0p1 [ 32.344327] Number of LUNs=1 [ 32.346219] g_multi gadget: Multifunction Composite Gadget [ 32.346229] g_multi gadget: g_multi ready [ OK ] Started Serial Getty on ttyS0. [ OK ] Started Serial Getty on ttyS3. [ OK ] Started Network Name Resolution. [ OK ] Started rc.pvr.service. [ OK ] Started Enable and configure wl18xx bluetooth stack. [ 32.785935] IPv6: ADDRCONF(NETDEV_UP): u***0: link is not ready [ OK ] Started Lightning Fast Webserver With Light System Requirements. [ OK ] Found device /dev/ttyGS0. [ 33.035969] NET: Registered protocol family 15 Starting weston.service... [ OK ] Started weston.service. Starting telnetd.service... [ OK ] Started Start USB gadget. [ OK ] Started Serial Getty on ttyGS0. [ OK ] Reached target Login Prompts. [ OK ] Started telnetd.service. [ 33.998580] Initializing XFRM netlink socket Starting busybox-udhcpd.service... Starting thttpd.service... [ OK ] Started busybox-udhcpd.service. [ OK ] Started thttpd.service. Starting rng-tools.service... [ OK ] Started Simple Network Management Protocol (SNMP) Daemon.. [ OK ] Started rng-tools.service. Starting SYSV: The kdump script provides the support:... [FAILED] Failed to start SYSV: The kdump script provides the support:. See 'systemctl status kdump.service' for details. Starting matrix-gui-2.0.service... [ OK ] Started matrix-gui-2.0.service. Starting parse-ip.service... Starting thermal-zone-init.service... [ OK ] Started thermal-zone-init.service. [ OK ] Started parse-ip.service. [ OK ] Reached target Multi-User System. Starting Update UTMP about System Runlevel Changes... [ OK ] Started Update UTMP about System Runlevel Changes. _____ _____ _ _ | _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_ | | _| .'| . | . | | __| _| . | | | -_| _| _| |__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_| |___| |___| Arago Project http://arago-project.org am335x-evm ttyS0 Arago 2017.05 am335x-evm ttyS0 am335x-evm login: root Login incorrect am335x-evm login: ^C _____ _____ _ _ | _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_ | | _| .'| . | . | | __| _| . | | | -_| _| _| |__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_| |___| |___| Arago Project http://arago-project.org am335x-evm ttyS0 Arago 2017.05 am335x-evm ttyS0 am335x-evm login: 我这里使用的是AM335X starter kit板子,用的最新的SDK,现在uboot和kernel编译后,下载到板子运行,能够正常登陆,如果我重新编译一下kernel后,再次启动的时候就提示我做标记的地方,导致登陆的时候一直提示Login incorrect,文件系统我是通过nfs挂载的方式。不知道这个问题怎么解决。。。各位高手支招,谢谢! |
2个回答
提示说/lib/systemd/system文件夹下的文件都要求移除可执行的权限,不知道什么地方的问题!
呵呵,自己把权限改了。。。。 |
只有小组成员才能发言,加入小组>>
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
1898 浏览 0 评论
TPS55340通电后输入端保险丝烧断,芯片输入和GND之间短路
3649 浏览 4 评论
5032 浏览 0 评论
请问如何用DM368对RGB格式的图片数据进行编码生成JPEG格式图片?
1736 浏览 1 评论
9386 浏览 8 评论
CC3100BOOST使用CC3200lunchXL进行烧录
670浏览 2评论
717浏览 1评论
TMS320F28034: 利用C2prog通过SCI给TMS320F28034烧录程序,出现错误提示:Bootloading... failed (invalid echo)!
678浏览 1评论
求DLPC350 Programmer’s Guide User's Guide 中文版说明书
1200浏览 1评论
1779浏览 1评论
GMT+8, 2024-4-27 07:50 , Processed in 0.631289 second(s), Total 80, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
