扫一扫,分享给好友
本人已经绘制了一个双面板,想把顶层和底层都输出成负片,但是老是报错,是什么原因?有人知道吗?
报错信息已经贴出来了,麻烦大神看下 (---------------------------------------------------------------------)( )( ARTWORK LOG )( )( Drawing : LASER_15_5.brd )( Software Version : 16.6P004 )( Date/time : Sat Jul 08 22:22:18 2017 )( )(---------------------------------------------------------------------) ---- Photoplot outline rectangle not found ... using drawing extentsResults from parameter file ... DEVICE-TYPE GERBER_RS274X OUTPUT-UNITS INCHES FILM-SIZE 2400000 1600000 FORMAT 2.5 ABORT-ON-ERROR NO SCALE 1 SUPPRESS-LEAD-ZEROES YES SUPPRESS-TRAIL-ZEROES NO SUPPRESS-EQUAL YES UNDEF-APT-CONT NO================================================================ PROCESSING FILM < TOP > TO FILE < E:/work/LASER/LASER-红外管发射/PCB/TOP.art > ...================================================================ FILM PARAMETERS : --------------------------------------------------------- Undefined line width 0.000 Mirror code NONE Rotate angle NONE Offset x: 0.000 Offset y: 0.000 Plot negative YES Suppress unconnected internal pads NO Draw holes only NO ERROR: aborting film - Layer polarity of layer ETCH/TOP does not match film polarity of Negative. DRC may be unreliable. WARNING: No thermal flash for padstack "PAD0402", regular pad used. WARNING: No thermal flash for padstack "SMD0D25X0D6RT", regular pad used. WARNING: No thermal flash for padstack "SMD2D6X3D6RT", regular pad used. WARNING: No thermal flash for padstack "SMD39SQU", regular pad used. WARNING: Null ANTI-PAD specified for padstack SMD_T_1D0X1D6 at (1200.787 -31.496). WARNING: No Photoplot Outline was found,negative shape outline will be determined by Board Outline WARNING: Segment with same start and end points at (728.346 -31.496) will be ignored. Increasing output accuracy may allow segment to be generated. APERTURES USED: --------------------------------------------------------- TYPE SIZE/NAME ROT MIRROR MODE --------------------------------------------------------- CIRCLE 0.00787 DARK CIRCLE 0.01000 DARK CIRCLE 0.01575 DARK CIRCLE 0.01968 DARK CIRCLE 0.02400 DARK CIRCLE 0.03000 DARK CIRCLE 0.06200 DARK CIRCLE 0.07000 CLEAR CIRCLE 0.07000 DARK CIRCLE 0.14900 CLEAR SQUARE 0.03937 0.000 NO DARK SQUARE 0.06200 0.000 NO DARK RECTANGLE 0.00984 x 0.02362 0.000 NO DARK RECTANGLE 0.00984 x 0.02362 90.000 NO DARK RECTANGLE 0.02587 x 0.02201 0.000 NO DARK RECTANGLE 0.02587 x 0.02201 90.000 NO DARK RECTANGLE 0.03937 x 0.06299 0.000 NO DARK RECTANGLE 0.09842 x 0.13780 90.000 NO DARK FLASH SYM FLASH0D7X1D0 0.000 NO CLEAR Error in TOP--halting output. Artwork file not generated. *** ERROR with TOP------------------------------------------------------ SUMMARY: *** ERROR with TOP ARTWORK Error |
2个回答
报这个错误
ERROR: aborting film - Layer polarity of layer ETCH/TOP does not match film polarity of Negative. DRC may be unreliable. WARNING: No thermal flash for padstack "PAD0402", regular pad used. WARNING: No thermal flash for padstack "SMD0D25X0D6RT", regular pad used. WARNING: No thermal flash for padstack "SMD2D6X3D6RT", regular pad used. WARNING: No thermal flash for padstack "SMD39SQU", regular pad used. WARNING: Null ANTI-PAD specified for padstack SMD_T_1D0X1D6 at (1200.787 -31.496). WARNING: No Photoplot Outline was found, negative shape outline will be determined by Board Outline WARNING: Segment with same start and end points at (728.346 -31.496) will be ignored. Increasing output accuracy may allow segment to be generated. |
怎么解决的,同问?
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
分享资深硬件工程师用cadence仿真DDR3 SDRAM视频---- sigxplorer信号完整性仿真例子 ...
64188 浏览 292 评论
4913 浏览 1 评论
26454 浏览 2 评论
李增老师:Cadence Allegro 17.2 如何制作逼真的3D PCB模型和进行3D设计检查
9804 浏览 11 评论
Cadence 17.2的brd能有什么方法用16.6的打开吗?
34277 浏览 2 评论
GMT+8, 2024-4-26 16:09 , Processed in 0.409628 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
