很高兴收到了瑞萨电子给与的地奇星RA6E2开发板,这个板子和STM32F103RC8T6板子很像,但是因为地奇星RA6E2是100MHz Arm® Cortex®-M33内核架构的核心板,比STM32F103RC8T6板子强一个内核级别,所以很开心,用这个板子做很多低功耗的应用了。
话不多少了,直接上干货。
论坛给出了原理图,非常的好用。
有原理图可知,LED连接的是P402引脚,所以只需要配好P402设置为输出即可
生成代码,打开KEIL工程
加入主函数,即可
#include "hal_data.h"
#include "main.h"
FSP_CPP_HEADER
void R_BSP_WarmStart(bsp_warm_start_event_t event);
FSP_CPP_FOOTER
main() is generated by the RA Configuration editor and is used to generate threads if an RTOS is used. This function
is called by main() when no RTOS is used.
void hal_entry(void)
/ TODO: add your own code here */
while(1)
LED_ON;
delay_ms(1500);
LED_OFF;
delay_ms(1500);
#if BSP_TZ_SECURE_BUILD
/* Enter non-secure code */
R_BSP_NonSecureEnter();
#endif
This function is called at various points during the startup process. This implementation uses the event that is
called right before main() to set up the pins.
@param[in] event Where at in the start up process the code is currently at
void R_BSP_WarmStart (bsp_warm_start_event_t event)
if (BSP_WARM_START_RESET == event)
#if BSP_FEATURE_FLASH_LP_VERSION != 0
/* Enable reading from data flash. */
R_FACI_LP->DFLCTL = 1U;
/* Would normally have to wait tDSTOP(6us) for data flash recovery. Placing the enable here, before clock and
* C runtime initialization, should negate the need for a delay since the initialization will typically take more than 6us. */
#endif
if (BSP_WARM_START_POST_C == event)
/* C runtime environment and system clocks are setup. */
/* Configure pins. */
R_IOPORT_Open(&IOPORT_CFG_CTRL, &IOPORT_CFG_NAME);
#if BSP_CFG_SDRAM_ENABLED
/* Setup SDRAM and initialize it. Must configure pins first. */
R_BSP_SdramInit(true);
#endif
FSP_CPP_HEADER
BSP_CMSE_NONSECURE_ENTRY void template_nonsecure_callable ();
/* Trustzone Secure Projects require at least one nonsecure callable function in order to build (Remove this if it is not required to build). */
FSP_CPP_FOOTER
#endif
板子预先的LED是闪烁的,但是闪的很快,我就改个慢的,防止蠢货说是一样的!!!!!
烧录代码,即可看到LED以1500ms的周期进行交替点亮熄灭
见顶部示意视频
来个常亮的
#include "main.h"
FSP_CPP_HEADER
FSP_CPP_FOOTER
while(1)
LED_ON;
// delay_ms(1500);
// LED_OFF;
// delay_ms(1500);
#endif
#endif
#endif
FSP_CPP_HEADER
FSP_CPP_FOOTER
#endif
只需注释掉一些即可
常亮见底部视屏
更多回帖
