乐鑫技术交流
直播中
刘慧
8年用户 1874经验值
私信 关注
[问答]
请问如何使用VScode IDF插件编译iot-solution程序?
环境相关
·开发板:ESP32-S2-Saola-1
·系统:Windows10
·IDE:VScode v1.63.1
·插件:Espressif IDF v1.2.0
·esp-idf版本:v4.3.1
·插件IDF安装路径:F:esp-idf
·插件TOOLS安装路径:S:WorkESP
·solution文件路径:F:ProjectIOTESP-solutionesp-iot-solution-usb-add_usb_solutions
问题描述
在经过多次尝试后我成功安装了插件,起初我根据网上的教程手动安装python3.8并配置环境但还是不行,后来发现插件自动会安装python所以把前面自己安装的都卸掉了。
尝试编译烧写hello world、IDF库的blink都可以正常工作。
然后我想要尝试ESP32-S2的USB功能,我下载了ESP-IOT-solution的USB分支,使用code打开usb_camera_wifi_transfer文件夹。
编译,分别报找不到路径、找不到USB组件Code: Select all
CMake Warning at CMakeLists.txt:9 (message):  Can't detect IOT_SOLUTION_PATH in your environment  CMake Error at F:/esp-idf/tools/cmake/build.cmake:191 (message):  Failed to resolve component 'usb'.
于是根据ESP-IOT-solution的指示,我尝试了在cmd中输入Code: Select all
F:esp-idf>export.batError: The following tools are not installed in your environment.  pythonPlease use the Windows Tool installer for setting up your environment.Download link: https://dl.espressif.com/dl/esp-idf/For more details please visit our website: https://docs.espressif.com/projects/esp-idf/en/latest/esp32/get-started/windows-setup.htmlF:esp-idf>cd S:WorkESPpython_envidf4.3_py3.8_envScriptsF:esp-idf>S:S:WorkESPpython_envidf4.3_py3.8_envScripts>F:esp-idfexport.batSetting IDF_PATH: F:esp-idfAdding ESP-IDF tools to PATH...ERROR: tool xtensa-esp32-elf has no installed versions. Please run 'F:esp-idfinstall.bat' to install it.ERROR: tool xtensa-esp32s2-elf has no installed versions. Please run 'F:esp-idfinstall.bat' to install it.ERROR: tool xtensa-esp32s3-elf has no installed versions. Please run 'F:esp-idfinstall.bat' to install it.ERROR: tool riscv32-esp-elf has no installed versions. Please run 'F:esp-idfinstall.bat' to install it.ERROR: tool esp32ulp-elf has no installed versions. Please run 'F:esp-idfinstall.bat' to install it.ERROR: tool esp32s2ulp-elf has no installed versions. Please run 'F:esp-idfinstall.bat' to install it.ERROR: tool cmake has no installed versions. Please run 'F:esp-idfinstall.bat' to install it.ERROR: tool openocd-esp32 has no installed versions. Please run 'F:esp-idfinstall.bat' to install it.ERROR: tool ninja has no installed versions. Please run 'F:esp-idfinstall.bat' to install it.ERROR: tool idf-exe has no installed versions. Please run 'F:esp-idfinstall.bat' to install it.ERROR: tool ccache has no installed versions. Please run 'F:esp-idfinstall.bat' to install it.ERROR: tool dfu-util has no installed versions. Please run 'F:esp-idfinstall.bat' to install it.
cmd中分别报监测不到python和找不到tools
在vscode的终端尝试输入后则反馈无法执行bat文件
请问现在需要如何配置才能正确更新solution所需的环境?
回帖(1)
杨秀英
2024-6-19 16:44:57
要使用VSCode IDF插件编译iot-solution程序,请按照以下步骤操作:
1. 打开VSCode,确保已安装Espressif IDF插件。
2. 打开您的iot-solution项目文件夹(F:ProjectIOTESP-solutionesp-iot-solution-usb-add_usb_solutions)。
3. 确保您的项目文件夹中包含以下文件:
   - `sdkconfig`:配置文件,用于设置项目参数。
   - `main`:包含主程序的文件夹。
   - `CMakeLists.txt`:CMake构建系统配置文件。
4. 连接您的ESP32-S2-Saola-1开发板到电脑。
5. 在VSCode中,打开终端(Terminal)。
6. 在终端中,运行以下命令以确保所有依赖项都已安装:
   python -m pip install --upgrade --user -r $IDF_PATH/requirements.txt
7. 运行以下命令以配置项目:
   idf.py set-target esp32s2
   idf.py menuconfig
   这将打开一个配置菜单,您可以在这里设置开发板参数和项目参数。
8. 保存配置并退出配置菜单。
9. 编译项目:
   idf.py build
   这将编译您的项目并生成一个`.bin`文件。
10. 如果编译成功,您可以烧录程序到开发板:
    idf.py -p COMx flash
    将`COMx`替换为您的ESP32-S2-Saola-1开发板的COM端口号。
11. 如果烧录成功,您的iot-solution程序将开始运行。
如果在编译或烧录过程中遇到问题,请检查以下几点:
- 确保开发板已正确连接并识别。
- 检查`sdkconfig`文件中的配置是否正确。
- 确保ESP32-S2-Saola-1开发板的固件版本与ESP-IDF版本兼容。
希望这些步骤能帮助您成功编译和烧录iot-solution程序。
举报
更多回帖
