电子发烧友论坛|
环境相关
·开发板:ESP32-S2-Saola-1 ·系统:Windows10 ·IDE:VScode v1.63.1 ·插件:Espressif IDF v1.2.0 ·esp-idf版本:v4.3.1 ·插件IDF安装路径:F:esp-idf ·插件TOOLS安装路径:S:WorkESP ·solution文件路径:F:ProjectIOTESP-solutionesp-iot-solution-usb-add_usb_solutions 问题描述 在经过多次尝试后我成功安装了插件,起初我根据网上的教程手动安装python3.8并配置环境但还是不行,后来发现插件自动会安装python所以把前面自己安装的都卸掉了。 尝试编译烧写hello world、IDF库的blink都可以正常工作。 然后我想要尝试ESP32-S2的USB功能,我下载了ESP-IOT-solution的USB分支,使用code打开usb_camera_wifi_transfer文件夹。 编译,分别报找不到路径、找不到USB组件 Code: Select all CMake Warning at CMakeLists.txt:9 (message): Can't detect IOT_SOLUTION_PATH in your environment CMake Error at F:/esp-idf/tools/cmake/build.cmake:191 (message): Failed to resolve component 'usb'. 于是根据ESP-IOT-solution的指示,我尝试了在cmd中输入 Code: Select all F:esp-idf>export.bat Error: The following tools are not installed in your environment. python Please use the Windows Tool installer for setting up your environment. Download link: https://dl.espressif.com/dl/esp-idf/ For more details please visit our website: https://docs.espressif.com/projects/esp-idf/en/latest/esp32/get-started/windows-setup.html F:esp-idf>cd S:WorkESPpython_envidf4.3_py3.8_envScripts F:esp-idf>S: S:WorkESPpython_envidf4.3_py3.8_envScripts>F:esp-idfexport.bat Setting IDF_PATH: F:esp-idf Adding ESP-IDF tools to PATH... ERROR: tool xtensa-esp32-elf has no installed versions. Please run 'F:esp-idfinstall.bat' to install it. ERROR: tool xtensa-esp32s2-elf has no installed versions. Please run 'F:esp-idfinstall.bat' to install it. ERROR: tool xtensa-esp32s3-elf has no installed versions. Please run 'F:esp-idfinstall.bat' to install it. ERROR: tool riscv32-esp-elf has no installed versions. Please run 'F:esp-idfinstall.bat' to install it. ERROR: tool esp32ulp-elf has no installed versions. Please run 'F:esp-idfinstall.bat' to install it. ERROR: tool esp32s2ulp-elf has no installed versions. Please run 'F:esp-idfinstall.bat' to install it. ERROR: tool cmake has no installed versions. Please run 'F:esp-idfinstall.bat' to install it. ERROR: tool openocd-esp32 has no installed versions. Please run 'F:esp-idfinstall.bat' to install it. ERROR: tool ninja has no installed versions. Please run 'F:esp-idfinstall.bat' to install it. ERROR: tool idf-exe has no installed versions. Please run 'F:esp-idfinstall.bat' to install it. ERROR: tool ccache has no installed versions. Please run 'F:esp-idfinstall.bat' to install it. ERROR: tool dfu-util has no installed versions. Please run 'F:esp-idfinstall.bat' to install it. cmd中分别报监测不到python和找不到tools 在vscode的终端尝试输入后则反馈无法执行bat文件 请问现在需要如何配置才能正确更新solution所需的环境? |
只有小组成员才能发言,加入小组>>
150 浏览 0 评论
946 浏览 0 评论
1674 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1334 浏览 1 评论
1234 浏览 1 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1254浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2340浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2528浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1052浏览 2评论
/9
GMT+8, 2025-12-2 22:20 , Processed in 0.733759 second(s), Total 70, Slave 53 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
596
