STM32
直播中
梅利号
9年用户 1563经验值
擅长:可编程逻辑
私信 关注
[问答]
如何用STM32F051把开关磁阻电机驱动起来啊?
什么样的PWM波形呢?有没有大神指导一下啊~只要动起来就行,不需要闭环什么的呢,求程序啊啊啊
回帖(1)
北京烤鸭
2024-5-7 17:42:38
要使用STM32F051驱动开关磁阻电机(SRD),您需要遵循以下步骤:
1. 硬件连接:首先,您需要将STM32F051与SRD连接。通常,SRD有4个相位线,您需要将它们连接到STM32F051的4个GPIO引脚。
2. 初始化GPIO:在STM32F051中,您需要将这4个GPIO引脚配置为输出模式,并设置初始状态为低电平。
3. 初始化定时器:为了生成PWM波形,您需要使用STM32F051的定时器。配置定时器的时钟源、预分频器、自动重载值等参数。
4. 生成PWM波形:使用定时器的捕获/比较模式生成PWM波形。您需要设置占空比和频率,以满足SRD的驱动要求。
5. 控制电机相位:根据SRD的相位顺序,通过改变GPIO引脚的电平来控制电机的相位。
以下是一个简单的STM32F051驱动SRD的示例程序:
```c
#include "stm32f0xx_hal.h"
// 定义GPIO引脚
#define SRD_PHASE_A_GPIO_PIN GPIO_PIN_0
#define SRD_PHASE_B_GPIO_PIN GPIO_PIN_1
#define SRD_PHASE_C_GPIO_PIN GPIO_PIN_2
#define SRD_PHASE_D_GPIO_PIN GPIO_PIN_3
// 定义定时器和通道
#define SRD_TIM_HANDLE htim1
#define SRD_TIM_CHANNEL TIM_CHANNEL_1
// 初始化GPIO
void SRD_GPIO_Init(void) {
  GPIO_InitTypeDef GPIO_InitStruct = {0};
  __HAL_RCC_GPIOA_CLK_ENABLE();
  GPIO_InitStruct.Pin = SRD_PHASE_A_GPIO_PIN | SRD_PHASE_B_GPIO_PIN | SRD_PHASE_C_GPIO_PIN | SRD_PHASE_D_GPIO_PIN;
  GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  GPIO_InitStruct.Pull = GPIO_NOPULL;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
  HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
  // 设置初始状态为低电平
  HAL_GPIO_WritePin(GPIOA, SRD_PHASE_A_GPIO_PIN, GPIO_PIN_RESET);
  HAL_GPIO_WritePin(GPIOA, SRD_PHASE_B_GPIO_PIN, GPIO_PIN_RESET);
  HAL_GPIO_WritePin(GPIOA, SRD_PHASE_C_GPIO_PIN, GPIO_PIN_RESET);
  HAL_GPIO_WritePin(GPIOA, SRD_PHASE_D_GPIO_PIN, GPIO_PIN_RESET);
// 初始化定时器
void SRD_TIM_Init(void) {
  __HAL_RCC_TIM1_CLK_ENABLE();
  SRD_TIM_HANDLE.Instance = TIM1;
  SRD_TIM_HANDLE.Init.Prescaler = 0;
  SRD_TIM_HANDLE.Init.CounterMode = TIM_COUNTERMODE_UP;
  SRD_TIM_HANDLE.Init.Period = 999;
  SRD_TIM_HANDLE.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
  SRD_TIM_HANDLE.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_DISABLE;
  HAL_TIM_PWM_Init(&SRD_TIM_HANDLE);
  TIM_HandleTypeDef *htim = &SRD_TIM_HANDLE;
  TIM_OC_InitTypeDef sConfigOC = {0};
  sConfigOC.OCMode = TIM_OCMODE_PWM1;
  sConfigOC.Pulse = 499; // 设置占空比为50%
  sConfigOC.OCPolarity = TIM_OCPOLARITY_HIGH;
  sConfigOC.OCFastMode = TIM_OCFAST_DISABLE;
  HAL_TIM_PWM_ConfigChannel(htim, &sConfigOC, SRD_TIM_CHANNEL);
  HAL_TIM_PWM_Start(&SRD_TIM_HANDLE, SRD_TIM_CHANNEL);
// 控制电机相位
void SRD_SetPhase(uint8_t phase) {
  switch (phase) {
    case 0: // 相位 A-B
      HAL_GPIO_WritePin(GPIOA, SRD_PHASE_A_GPIO_PIN, GPIO_PIN_SET);
      HAL_GPIO_WritePin(GPIOA, SRD_PHASE_B_GPIO_PIN, GPIO_PIN_SET);
      break;
    case 1: // 相位 B-C
      HAL_GPIO_WritePin(GPIOA, SRD_PHASE_C_GPIO_PIN, GPIO_PIN_SET);
      break;
    case 2: // 相位 C-D
      HAL_GPIO_Write
举报
更多回帖
