STM32
直播中
djfldsthtr
9年用户 1021经验值
擅长:光电显示
私信 关注
[问答]
stm8l151C6 RC522物理SPI没有SCK时钟是怎么回事?
调试好几天了,在网上试了好多方法还是不通,希望有大神给看下到底代码写的对不对,大家往下看:
硬件连接:
      使用的单片机为stm8l151C6,物理SPI和一个RC522芯片进行连接
      PB4:NSS片选
      PB5:SCK
      PB6:MOSI
      PB7:MISO
      PC4:RST(复位)
      PD6:pwr(电源,自己为低功耗设计)
问题:
      物理SPI初始化使能之后一直写数据,用示波器检测SCK引脚时钟,发现没有时钟信号
      程序一直卡在while (SPI_GetFlagStatus(SPI1, SPI_FLAG_RXNE) == RESET)
      模拟SPI通信没有问题
代码如下:
  • void main(void)
  •     hardware_init();
  •     //enableInterrupts();
  •     while (1)
  • //        ReadRawRC(0x05);
  •         SPIWritebyte(0xAA);
  • //        BSP_RFID_WriteRegister(CommandReg,0xAA);
  • //      gpio_set_low(PORTB, PIN5);
  • //      gpio_set_high(PORTB, PIN5);
  • void hardware_init(void)
  •     u8 rv = 0;
  •     u8 ctrl_reg = 0, ver_reg = 0;
  • //    gpio_set_high(PORTD, PIN7);
  •     // system clock init
  •     sysclk_init_hsi(CLK_SYSCLKDiv_1);
  •     //CLK_HSIPrescalerConfig(CLK_PRESCALER_HSIDIV1);
  •     /* Select HSE as system clock source */
  • //  CLK_SYSCLKSourceSwitchCmd(ENABLE);
  • //  CLK_SYSCLKSourceConfig(CLK_SYSCLKSource_HSE);
  •   /*High speed external clock prescaler: 1*/
  • //  CLK_SYSCLKDivConfig(CLK_SYSCLKDiv_1);
  •     // com load configuration   init
  •     com_load_config(com_cfg, 1);
  •     com_init(COM1, 2400, USART_WordLength_9b, USART_StopBits_1, USART_Parity_Even, USART_Mode_All, ENABLE, 0);
  •     com_recv_init(COM1);
  •     /* Check if the system has resumed from IWDG reset */
  •     if (RST_GetFlagStatus(RST_FLAG_IWDGF) != RESET)
  •         /* Clear IWDGF Flag */
  •         RST_ClearFlag(RST_FLAG_IWDGF);
  •         printf("RST_FLAG_IWDGFrn");
  •     // rtc init
  •     rtc_init();
  •     BSP1_RFID_LoadConfig( rfid_config); //加载管脚配置
  •     CLK_PeripheralClockConfig(CLK_Peripheral_SPI1, ENABLE);
  •     GPIO_Init(GPIOB, GPIO_Pin_4, GPIO_Mode_Out_PP_High_Fast); //NSS片选
  •     GPIO_Init(GPIOB, GPIO_Pin_5, GPIO_Mode_Out_PP_High_Fast); //SCK
  •     GPIO_Init(GPIOB, GPIO_Pin_6, GPIO_Mode_Out_PP_High_Fast); //MOSI
  •     //主机模式,配置为输入
  •     GPIO_Init(GPIOB, GPIO_Pin_7, GPIO_Mode_In_PU_No_IT); //MISO
  •     BSP1_RFID_PowerOn();        //给RC522芯片上电
  •     //BSP1_RFID_PowerOff();
  •     SPI_DeInit(SPI1);
  •     SPI_Init(SPI1, SPI_FirstBit_MSB, SPI_BaudRatePrescaler_8, SPI_Mode_Master,SPI_CPOL_Low, SPI_CPHA_1Edge,SPI_Direction_2Lines_FullDuplex, SPI_NSS_Soft, 0x07);
  •     //SPI_Init(SPI1, SPI_FirstBit_MSB, SPI_BaudRatePrescaler_128, SPI_Mode_Master,SPI_CPOL_High, SPI_CPHA_2Edge,SPI_Direction_2Lines_FullDuplex, SPI_NSS_Soft, 0x07);
  •     SPI_Cmd(SPI1, ENABLE);  /* 使能SPI */
  •     rv = BSP1_RFID_Reset( ctrl_reg,  ver_reg);  //和PcdReset库函数一模一样
  •     printf("ctrl_reg:%02X, ver_reg:%02Xrn", ctrl_reg, ver_reg);
  •     if (rv != 0)
  •         printf("rfid init errorrn");
  •     BSP_RFID_AntennaOff();
  •     delay_ms(1);
  •     BSP_RFID_AntennaOn();
  •     BSP_RFID_ConfigISOType('A');        //针对ISO14443A型卡进行初始化
  •     return;
  • /*! brief
  • *       rc522 reset
  • * return
  • *       MI_OK       - success
  • *       MI_ERR      - failure
  • char BSP1_RFID_Reset(u8 *ctrl_reg, u8 *version)
  •     unsigned char val = 0;
  •     /* set rc522 rst to push pull output state , and set it to 0 */
  •     BSP_GPIO_Init(rfid_config_handler->rst.port, rfid_config_handler->rst.pin, GPIO_Mode_Out_PP_Low_Fast);
  • //    /* set rs522 nss to push pull output state, and set it to 1, disable sck,mosi,miso pin */
  • //    BSP_GPIO_Init(rfid_config_handler->nss.port, rfid_config_handler->nss.pin, GPIO_Mode_Out_PP_High_Fast);
  • //    /* set rc522 sck to push pull output state, and set it to 1 */
  • //    BSP_GPIO_Init(rfid_config_handler->sck.port, rfid_config_handler->sck.pin, GPIO_Mode_Out_PP_High_Fast);
  • //    /* set rc522 miso to push up input state*/
  • //    BSP_GPIO_Init(rfid_config_handler->miso.port, rfid_config_handler->miso.pin, GPIO_Mode_In_PU_No_IT);
  • //    //BSP_GPIO_Init(rfid_config_handler->miso.port, rfid_config_handler->miso.pin, GPIO_Mode_Out_PP_High_Fast);
  • //    /* set rc522 mosi to push pull output state, and set it to 1 */
  • //    BSP_GPIO_Init(rfid_config_handler->mosi.port, rfid_config_handler->mosi.pin, GPIO_Mode_Out_PP_High_Fast);
  •     delay_us(10);
  •     /* rs522 will be reset by setting rst to execute 1-0-1 sequence. */
  •     BSP_GPIO_SetHigh(rfid_config_handler->rst.port, rfid_config_handler->rst.pin);
  •     delay_us(10);
  •     BSP_GPIO_SetLow(rfid_config_handler->rst.port, rfid_config_handler->rst.pin);
  •     delay_us(10);
  •     delay_us(10);
  •     //    RC522_RST_H();
  •     //    delay_us(10);
  •     //    RC522_RST_L();
  •     //    delay_us(10);
  •     //    RC522_RST_H();
  •     //    delay_us(10);
  •     WriteRawRC(CommandReg,PCD_RESETPHASE);
  •     delay_us(10);
  •     WriteRawRC(ModeReg,0x3D);            //和Mifare卡通讯,CRC初始值0x6363
  •     WriteRawRC(TReloadRegL,30);
  •     WriteRawRC(TReloadRegH,0);
  •     WriteRawRC(TModeReg,0x8D);
  •     WriteRawRC(TPrescalerReg,0x3E);
  •     WriteRawRC(TxAutoReg,0x40);//必须要
  •     val = ReadRawRC(ControlReg);
  •     if (val == 0xFF)
  •         //printf("CtlReg:%02Xrn", val);
  •         return MI_ERR;
  •     *ctrl_reg = val;
  •     val = ReadRawRC(VersionReg);
  •     if (val == 0xFF)
  •         //printf("Ver:%02Xrn", val);
  •         return MI_ERR;
  •     *version = val;
  • //    BSP_RFID_AntennaOff();
  • //    BSP_RFID_ConfigISOType('A');
  • //    delay_ms(1);
  • //    BSP_RFID_AntennaOn();
  •     return MI_OK;
  • void SPIWritebyte(u8 Byte)
  •   u16 retry=0;
  • //  u8 rv = 0;
  •   while (SPI_GetFlagStatus(SPI1, SPI_FLAG_TXE) == RESET)
  •     retry++;
  •     if(retry>200)
  •       return;
  •   SPI_SendData(SPI1, Byte);
  •   retry=0;
  •   //while (SPI_GetFlagStatus(SPI1, SPI_FLAG_RXNE) == RESET)
  •   while (SPI_GetFlagStatus(SPI1, SPI_FLAG_BSY) == SET)
  •     retry++;
  •     if(retry>400)return;
  •   while (SPI_GetFlagStatus(SPI1, SPI_FLAG_RXNE) == RESET)
  •     retry++;
  •   SPI_ReceiveData(SPI1);
回帖(1)
马慧霞
2024-4-30 09:40:55
GPIO初始化的时候,注意是不是有复用功能,
把外设去掉,单独用了测试函数测试一下看是否有信号
举报
更多回帖
