STM32
直播中
凌流浪
7年用户 891经验值
擅长:可编程逻辑 电源/新能源
私信 关注
[问答]
STM32F411RE宏定义STM32F411xE和#define USE_HSE_BYPASS在哪里找?
我手头有一片nucelo STM32F411RE板子,是透过有源振荡器,osc in ,osc out (空接),然后这个振荡器是由 through STLINK MCO pin of STM32F103 microcontroller. The frequencycannot be changed and is fixed at 8 MHz.
我找不到这两个宏定义STM32F411xE,#define USE_HSE_BYPASS,这个在那边可以找的到
#if defined(STM32F411xE)    /*!< Uncomment the following line if you need to clock the STM32F411xE by HSE Bypass
     through STLINK MCO pin of STM32F103 microcontroller. The frequency cannot be changed
     Hardware configuration needed for Nucleo Board:
     ?SB54, SB55 OFF
     ?R35 removed
     ?SB16, SB50 ON */
/* #define USE_HSE_BYPASS */     //这叙述为何被屏蔽掉
#if defined(USE_HSE_BYPASS)
#define HSE_BYPASS_INPUT_FREQUENCY   8000000
#endif /* USE_HSE_BYPASS */
#endif /* STM32F411xE */
回帖(1)
王莉淳
2024-4-23 14:45:42
注释里不是说过吗,叫你需要HSE Baypass就把那个注释取消掉呀,就是你中文注释那一行,对于NUCLEO硬件需要把SB54,SB55这两个地方断开,把R35移除,把SB16,SB50闭合
举报
更多回帖
