STM32
直播中
王越建
8年用户 1530经验值
私信 关注
[问答]
用TIM6做定时器不能进入中断怎么解决?
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  /* MCU Configuration--------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  /* Configure the system clock */
  SystemClock_Config();
  /* USER CODE BEGIN SysInit */
  /* USER CODE END SysInit */
  /* Initialize all configured peripherals */
  MX_GPIO_Init();
  MX_DMA_Init();
  MX_ADC1_Init();
  MX_TIM1_Init();
  MX_TIM6_Init();
  MX_USART1_UART_Init();
  /* USER CODE BEGIN 2 */
        HAL_ADCEx_Calibration_Start( hadc1);//ADC自校验
        HAL_ADC_Start_DMA( hadc1,(uint32_t *)ADC_ConvertedData,ADC_SAMPLE);//启动AD转换并使能DMA传输和中断
        HAL_TIM_Base_Start_IT( htim1);          //初始化定时器中断
  HAL_TIM_Base_Start_IT( htim6);          //初始化定时器中断
        HAL_TIMEx_PWMN_Start( htim1,TIM_CHANNEL_1);
        HAL_TIM_PWM_Start( htim1,TIM_CHANNEL_1);
        //__HAL_TIM_CLEAR_FLAG( htim6,TIM_FLAG_UPDATE);  //这是关断定时器语句
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
    /* USER CODE END WHILE */
    /* USER CODE BEGIN 3 */
    HAL_GPIO_TogglePin(K_OUT_GPIO_Port, K_OUT_Pin);
                HAL_GPIO_TogglePin(FAN_GPIO_Port, FAN_Pin);
                HAL_GPIO_TogglePin(K_IN_GPIO_Port, K_IN_Pin);
                HAL_GPIO_TogglePin(GPIOB,LED_LV_Pin);
    HAL_Delay(500);
    ADC_ConvertedData[3];
    //htim1.Instance->sTimerxRegs[0].PERxR = 50000;//通过修改重装载值PER,从而修改PWM的频率  htim1
    //htim1.Instance->sTimerxRegs[0].CMP1xR = 11504;//通过修改比较值CMP,从而修改占空比
  /* USER CODE END 3 */
  * @brief System Clock Configuration
  * @retval None
void SystemClock_Config(void)
  RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
  RCC_PeriphCLKInitTypeDef PeriphClkInit = {0};
  /** Configure the main internal regulator output voltage
  HAL_PWREx_ControlVoltageScaling(PWR_REGULATOR_VOLTAGE_SCALE1);
  /** Initializes the CPU, AHB and APB busses clocks
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
  RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  RCC_OscInitStruct.HSIDiv = RCC_HSI_DIV1;
  RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
  RCC_OscInitStruct.PLL.PLLM = RCC_PLLM_DIV1;
  RCC_OscInitStruct.PLL.PLLN = 16;
  RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
  RCC_OscInitStruct.PLL.PLLQ = RCC_PLLQ_DIV2;
  RCC_OscInitStruct.PLL.PLLR = RCC_PLLR_DIV4;
  if (HAL_RCC_OscConfig( RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
  if (HAL_RCC_ClockConfig( RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
    Error_Handler();
  /** Initializes the peripherals clocks
  PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_USART1|RCC_PERIPHCLK_ADC
                              |RCC_PERIPHCLK_TIM1;
  PeriphClkInit.Usart1ClockSelection = RCC_USART1CLKSOURCE_PCLK1;
  PeriphClkInit.AdcClockSelection = RCC_ADCCLKSOURCE_SYSCLK;
  PeriphClkInit.Tim1ClockSelection = RCC_TIM1CLKSOURCE_PLL;
  if (HAL_RCCEx_PeriphCLKConfig( PeriphClkInit) != HAL_OK)
    Error_Handler();
/* USER CODE BEGIN 4 */
void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim)
  // Prevent unused argument(s) compilation warning
    UNUSED(htim);
    HAL_GPIO_TogglePin(GPIOB,GPIO_PIN_4);            //只有定时器有中断,就翻转一次引脚电平
    static unsigned char ledState = 0;
    if (htim == ( htim6))
        if (ledState == 0)
            HAL_GPIO_WritePin(GPIOB,GPIO_PIN_4,GPIO_PIN_RESET);
        else
            HAL_GPIO_WritePin(GPIOB,GPIO_PIN_4,GPIO_PIN_SET);
        ledState = !ledState;
/* USER CODE END 4 */
回帖(1)
周娟
2024-4-9 17:28:35
HAL_TIM_PeriodElapsedCallback 这个函数写只能写一次,在函数内判断是哪个定时器的中断。
你 HAL_TIM_PeriodElapsedCallback 写两次是不行的,第二次的不会被编译。
举报
更多回帖
