STM32
直播中
蔡鼎瑾
9年用户 1115经验值
私信 关注
[问答]
STM32f3在main里面应该怎样调用HAL库实现带PEC的基本传输?
刚接触SMBUS,想实现一下它的基本传输,平台是f3discovery;我用Cube选择了two-wire模式的SMBus1和SMBus2生成了基本代码,打算把1作为master,2作为slave采用中断方式去完成收发的demo(不知道可不可行),我在生成的SMBus2配置项中把ownaddress1 设置为0xA0 即从机地址;
请问在main里面应该怎样调用HAL库能实现带PEC的基本传输?
回帖(1)
丁冬芹
2024-3-25 17:19:37
要在main函数中调用HAL库实现带PEC的基本传输,你可以按照以下步骤进行操作:
1. 在main函数的开头,添加HAL库的头文件:
```c
#include "stm32f3xx_hal.h"
2. 在main函数中初始化HAL库:
```c
HAL_Init();
3. 配置SMBus1和SMBus2的GPIO引脚和时钟:
```c
__HAL_RCC_GPIOA_CLK_ENABLE(); // 使能GPIOA时钟
__HAL_RCC_GPIOB_CLK_ENABLE(); // 使能GPIOB时钟
/* 配置GPIO引脚 */
GPIO_InitTypeDef GPIO_InitStruct;
GPIO_InitStruct.Pin = GPIO_PIN_6 | GPIO_PIN_7;
GPIO_InitStruct.Mode = GPIO_MODE_AF_OD;
GPIO_InitStruct.Pull = GPIO_PULLUP;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
GPIO_InitStruct.Alternate = GPIO_AF4_I2C1;
HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
GPIO_InitStruct.Pin = GPIO_PIN_10 | GPIO_PIN_11;
GPIO_InitStruct.Alternate = GPIO_AF4_I2C2;
4. 初始化SMBus1和SMBus2的外设:
```c
__HAL_RCC_I2C1_CLK_ENABLE(); // 使能I2C1时钟
__HAL_RCC_I2C2_CLK_ENABLE(); // 使能I2C2时钟
/* 配置SMBus1 */
I2C_HandleTypeDef hi2c1;
hi2c1.Instance = I2C1;
hi2c1.Init.ClockSpeed = 100000; // 设置时钟速度
hi2c1.Init.DutyCycle = I2C_DUTYCYCLE_2;
hi2c1.Init.OwnAddress1 = 0xA0;
hi2c1.Init.AddressingMode = I2C_ADDRESSINGMODE_7BIT;
hi2c1.Init.DualAddressMode = I2C_DUALADDRESS_DISABLE;
hi2c1.Init.OwnAddress2 = 0xFF;
hi2c1.Init.GeneralCallMode = I2C_GENERALCALL_DISABLE;
hi2c1.Init.NoStretchMode = I2C_NOSTRETCH_DISABLE;
HAL_I2C_Init(&hi2c1);
/* 配置SMBus2 */
I2C_HandleTypeDef hi2c2;
hi2c2.Instance = I2C2;
hi2c2.Init.ClockSpeed = 100000; // 设置时钟速度
hi2c2.Init.DutyCycle = I2C_DUTYCYCLE_2;
hi2c2.Init.OwnAddress1 = 0xA0;
hi2c2.Init.AddressingMode = I2C_ADDRESSINGMODE_7BIT;
hi2c2.Init.DualAddressMode = I2C_DUALADDRESS_DISABLE;
hi2c2.Init.OwnAddress2 = 0xFF;
hi2c2.Init.GeneralCallMode = I2C_GENERALCALL_DISABLE;
hi2c2.Init.NoStretchMode = I2C_NOSTRETCH_DISABLE;
HAL_I2C_Init(&hi2c2);
5. 在main函数中使用HAL库的函数进行数据传输:
```c
uint8_t dataBuffer[10] = {0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08, 0x09, 0x0A};
uint8_t receiveBuffer[10] = {0};
HAL_I2C_Master_Transmit(&hi2c1, 0xA0, dataBuffer, 10, 1000); // 向从机发送数据
HAL_I2C_Master_Receive(&hi2c2, 0xA0, receiveBuffer, 10, 1000); // 从从机接收数据
注意,在上面的代码中,我们使用了`HAL_I2C_Master_Transmit`函数向从机发送数据,使用了`HAL_I2C_Master_Receive`函数从从机接收数据。可以根据你的需求调整这些函数的参数。
希望这些信息能帮助到你!请随时告诉我如果你有任何其他问题。
举报
更多回帖
