我这边按照你的流程写了个简单demo,运行4.1.1,没有发现有什么问题。
按照你的说明,我理解的EVT2是对Running的ACK;EVT6是对Stop的ACK。
下方的代码中:
- worker线程等待EVT_RUN;然后发送EVT2,修改状态为TRUE;然后等待EVT3,EVT4和EVT Stop,其中,等到EVT Stop后发送EVT6。
- controller线程发出EVT Run,等待EVT2,等待EVT6;
- int_sim用于模拟你的中断,发出EVT3,EVT4和EVT Stop。
在你的代码中,为什么控制线程等待EVT2需要将timeout设置为0?我的模拟代码中设置为FOREVER。
- #include
- #define DBG_TAG "main"
- #define DBG_LVL DBG_LOG
- #include
- #define EVT_RUN (1<<0)
- #define EVT_STOP (1<<1)
- #define EVT_2 (1<<2)
- #define EVT_3 (1<<3)
- #define EVT_4 (1<<4)
- #define EVT_6 (1<<6)
- void worker_entry(void *arg);
- void controller_entry(void *arg);
- void int_sim_entry(void *arg);
- static struct rt_event evt;
- int main(void)
- rt_thread_t tid;
- rt_event_init(&evt, "event", RT_IPC_FLAG_FIFO);
- tid = rt_thread_create("worker", worker_entry, RT_NULL, 2048, 15, 0);
- if(tid) {
- LOG_D("worker startup");
- rt_thread_startup(tid);
- tid = rt_thread_create("controller", controller_entry, RT_NULL, 2048, 14, 0);
- if(tid) {
- LOG_D("controller startup");
- tid = rt_thread_create("int_sim", int_sim_entry, RT_NULL, 2048, 11, 0);
- if(tid) {
- LOG_D("demo_int startup");
- return RT_EOK;
- rt_err_t err;
- rt_uint32_t flags;
- rt_bool_t state_run = RT_FALSE;
- while(1) {
- err = rt_event_recv(&evt,EVT_RUN,
- RT_EVENT_FLAG_OR|RT_EVENT_FLAG_CLEAR,
- RT_WAITING_FOREVER,&flags);
- LOG_I("State - RUNNING , flags = %d", flags);
- state_run = RT_TRUE;
- rt_event_send(&evt, EVT_2);
- while(RT_TRUE == state_run) {
- err = rt_event_recv(&evt,EVT_3|EVT_4|EVT_STOP,
- 1000,&flags);
- if (err == RT_EOK) {
- switch(flags) {
- case EVT_3:
- LOG_D("State - RUNNING EVT_3 , flags = %d",flags);
- break;
- case EVT_4:
- LOG_D("State - RUNNING EVT_4 , flags = %d",flags);
- break;
- case EVT_STOP:
- LOG_I("State - STOP Received , flags = %d",flags);
- rt_event_send(&evt,EVT_6);
- state_run = RT_FALSE;
- break;
- default:
- LOG_D("State - Unknown , flags = %d", flags);
- } else{
- LOG_D("Timeout");
- while(1)
- rt_event_send(&evt,EVT_RUN);
- rt_event_recv(&evt,EVT_2,
- LOG_I("State - Run Ack , flags = %d",flags);
- rt_event_recv(&evt,EVT_6,
- LOG_I("State - Stop Ack , flags = %d",flags);
- rt_uint32_t count = 0;
- while(++count)
- if(0 == (count %2) )
- rt_event_send(&evt, EVT_3);
- else
- rt_event_send(&evt, EVT_4);
- if(count == 20)
- rt_event_send(&evt, EVT_STOP);
- count = 0;
- rt_thread_delay(1000);
下方的代码中:
- #include
- #include
- int main(void)
- rt_thread_t tid;
- if(tid) {
- if(tid) {
- if(tid) {
- return RT_EOK;
- rt_err_t err;
- while(1) {
- 1000,&flags);
- switch(flags) {
- case EVT_3:
- break;
- case EVT_4:
- break;
- case EVT_STOP:
- break;
- default:
- } else{
- LOG_D("Timeout");
- while(1)
- while(++count)
- else
- if(count == 20)
- count = 0;
举报
