NXP MCU 技术论坛
直播中
周棠亨
9年用户 1161经验值
擅长:可编程逻辑 电源/新能源
私信 关注
[问答]
K32L2A31A写入LPSPI0->TDR的硬故障怎么解决?
我尝试为一个非常小的引导加载程序编写一个函数。哪个应该向显示器发送命令。
然而,最后一条语句“LPSPI0->TDR = (uint32_t)(0x20<<8);” 造成硬故障,我不知道为什么。谁能帮我?MCU 是 K32L2A31A。
__attribute__ ((naked, section(".after_vectors.reset")))
void showBLMInfo(void){
        //Connect CMP1 with TPM2
        TRGMUX_TPM2 = TRGMUX_TRGCFG_SEL0(0b100111);
        //Comparator for regulated Chargepump
        PCC_CMP1 = PCC_CLKCFG_CGC_MASK; //Clock enable
        //Caution Vin2 as reference is VDD, datasheet is wrong here!
        CMP1->DACCR = CMP_DACCR_DACEN_MASK | CMP_DACCR_VRSEL_MASK | CMP_DACCR_VOSEL(0x2E);
        CMP1->MUXCR = CMP_MUXCR_MSEL(7) | CMP_MUXCR_PSEL(0);
        CMP1->CR1 = CMP_CR1_EN_MASK;
        //Generate PWM for Chargepump
        PCC_TPM2 = PCC_CLKCFG_CGC_MASK | PCC_CLKCFG_PCS(2); //Clock enable, Fast IRC
        TPM2->CONF = TPM_CONF_CPOT_MASK | TPM_CONF_TRGSEL(0) | TPM_CONF_DBGMODE_MASK;
        TPM2->CNT = 0;
        TPM2->MOD = 10;
        TPM2->CONTROLS[1].CnSC = TPM_CnSC_ELSB_MASK  | TPM_CnSC_MSB_MASK;
        TPM2->CONTROLS[1].CnV = 5;
        //Enable Chargepump
        TPM2->SC = TPM_SC_CMOD(1) | TPM_SC_PS(2);
        //GPIO
        //GPIO_SPI0_CS_DISP_GPIO->PCOR = GPIO_SPI0_CS_DISP_GPIO_PIN_MASK;
        //EN_U_BAT, EN_DISP
        PCC_PORTE = PCC_CLKCFG_CGC_MASK; //Clock enable PORT E
        PCC_PORTD = PCC_CLKCFG_CGC_MASK; //Clock enable PORT D
        PORTE->PCR[1] = PORT_PCR_MUX(1); //EN_U_BAT
        PORTE->PCR[25] = PORT_PCR_MUX(2); //EN_DISP
        PORTD->PCR[0] = PORT_PCR_MUX(2); //CS
        PORTD->PCR[1] = PORT_PCR_MUX(2); //SCK
        PORTD->PCR[2] = PORT_PCR_MUX(2); //MOSI
        GPIOE->PDDR = (1U << 25U) | (1U << 1U);
        GPIOE->PSOR = (1U << 25U) | (1U << 1U);
        //1Hz Refresh Clock
        //RTC->CR |= RTC_CR_CPE(1);
        PCC_LPSPI0 = PCC_CLKCFG_CGC_MASK | PCC_CLKCFG_PCS(2); //Clock enable
        LPSPI0->CR = LPSPI_CR_DBGEN_MASK | LPSPI_CR_MEN_MASK;
        LPSPI0->CFGR1 = LPSPI_CFGR1_MASTER_MASK | LPSPI_CFGR1_PCSPOL(1) | LPSPI_CFGR1_AUTOPCS_MASK;
        LPSPI0->CCR = LPSPI_CCR_PCSSCK(11)|LPSPI_CCR_SCKPCS(2)|LPSPI_CCR_DBT(4);
        //Send Display clear command
        LPSPI0->TCR = LPSPI_TCR_FRAMESZ(15) | LPSPI_TCR_PRESCALE(4) | LPSPI_TCR_TXMSK_MASK | LPSPI_TCR_CONT_MASK; //16bit Transfer
非常感谢。
更多回帖
