我这边使用S32K314的SPI Slave DMA功能发送数据遇到一个问题,SPI采用SPI0,TX DMA0 RX DMA1。
SPI需要传输1024个字节,发送数据第一帧数据正常,后续帧都会出现前4个字节都会被随机覆盖,其他1020个数据正常。 例如, 发送 AA 55 00 01 01 02 03 04 ... 通过逻辑分析仪抓包数据为 XX XX XX XX 01 02 03 04 ... SPI和Tx DMA初始化配置: LPSPI0_CLK_ENABLE(); IP_LPSPI_0->CFGR1 = LPSPI_CFGR1_MASTER(0) | LPSPI_CFGR1_PINCFG(0) | LPSPI_CFGR1_OUTCFG(0) | LPSPI_CFGR1_PCSCFG(0) | LPSPI_CFGR1_MATCFG(0) | LPSPI_CFGR1_PCSPOL(0) | LPSPI_CFGR1_NOSTALL(0); IP_LPSPI_0->FCR = LPSPI_FCR_RXWATER(0) | LPSPI_FCR_TXWATER(0); IP_LPSPI_0->TCR = LPSPI_TCR_CPOL(1) | LPSPI_TCR_CPHA(1) | LPSPI_TCR_PCS(1) | LPSPI_TCR_LSBF(0) | LPSPI_TCR_BYSW(1) | LPSPI_TCR_CONT(0) | LPSPI_TCR_CONTC(0) | LPSPI_TCR_TXMSK(0) | LPSPI_TCR_RXMSK(0) LPSPI_TCR_FRAMESZ(31 - 1) | LPSPI_TCR_WIDTH(0); IP_LPSPI_0->CR = LPSPI_CR_MEN(1); DMA_CLK_ENABLE(); DMAMUX_0_CLK_ENABLE(); DMA_TCD0_CLK_ENABLE(); IP_DMAMUX_0->CFCFG[3] = DMAMUX_CHCFG_SOURCE(43); NVIC_EnableIRQ((IRQn_Type)(DMATCD0_IRQn)); SPI和Tx DMA发送前配置: IP_LPSPI_0->CR |= LPSPI_CR_RRF_MASK | LPSPI_CR_RTF_MASK; IP_LPSPI_0->DER = ~(LPSPI_DER_TDDE_MASK | LPSPI_DER_RDDE_MASK); IP_TCD->TCD0_SADDR = (uint32_t)SrcAddr; IP_TCD->TCD0_DADDR = (uint32_t) IP_LPSPI_0->TDR; IP_TCD->TCD0_ATTR = DMA_TCD_TCD0_ATTR_SMOD(0) | DMA_TCD_TCD0_ATTR_SSIZE(2) | DMA_TCD_TCD0_ATTR_DMOD(0) | DMA_TCD_TCD0_ATTR_DSIZE(2); IP_TCD->TCD0_SOFF = 4; IP_TCD->TCD0_DOFF = 0; IP_TCD->NBYTES0.TCD0_NBYTES_MLOFFNO = 4; IP_TCD->BITER0.TCD0_BITER_ELINKNO = DMA_TCD_TCD0_BITER_ELINKNO_BITER(256); IP_TCD->CITER0.TCD0_CITER_ELINKNO = DMA_TCD_TCD0_CITER_ELINKNO_CITER(256); IP_TCD->TCD0_SLAST_SDA = 0; IP_TCD->TCD0_DLAST_SGA = 0; IP_TCD->TCD0_CSR |= DMA_TCD_TCD0_CSR_INTMAJOR(1) ~DMA_TCD_TCD0_CSR_START_MASK; IP_LPSPI_0->DER |= LPSPI_DER_TDDE_MASK | LPSPI_DER_RDDE_MASK; IP_TCD->CH0_INT = DMA_TCD_CH0_INT_INT(0); IP_TCD->CH0_CSR = DMA_TCD_CH0_CSR_ERQ(1); IP_DMAMUX_0->CFCFG[3] |= DMAMUX_CHCFG_ENBL_MASK; TX Dma中断函数: void DMA0_IRQHandler(void) { IP_LPSPI_0->DER = ~LPSPI_DER_TDDE_MASK; LP_LPSPI_0->CR |= LPSPI_CR_RTF_MASK; IP_LPSPI_0->CH0_CSR |= DMA_TCD_CH0_CSR_DONE(1); IP_LPSPI_0->CH0_INT |= DMA_TCD_CH0_INT_INT(1); IP_DMAMUX_0->CFCFG[3] = ~DMAMUX_CHCFG_ENBL_MASK; IP_TCD->CH0_CSR = DMA_TCD_CH0_CSR_ERQ(0); Spi0_TxHandler(); } |
只有小组成员才能发言,加入小组>>
1876个成员聚集在这个小组
加入小组我的项目我做主,使用GN+Ninja来完成构建系统(VSCode开发RT106X)
36227 浏览 0 评论
NXP IMX8应用处理器快速入门必备:技巧、使用、设计指南
4324 浏览 0 评论
5953 浏览 1 评论
6693 浏览 0 评论
NXP i.MX6UL开发板(linux系统烧录+规格+硬件+模块移植)使用手册
4144 浏览 0 评论
565浏览 2评论
求助,S32G上Core M启动后如何让Core A在Flash指定位置加载uboot?
555浏览 2评论
ESP32-WROVER-IE + LAN8720以太网,GPIO0电压只有1.6v,无法正常进入spi flash boot模式如何解决?
550浏览 2评论
求分享适用于PN7160 Android的NFC工厂测试应用程序
636浏览 2评论
697浏览 2评论
GMT+8, 2024-10-2 20:39 , Processed in 1.005586 second(s), Total 76, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
