嵌入式技术论坛
直播中
刘润生
8年用户 757经验值
私信 关注
[经验]
RTT RA2L1 HS3003采集温湿度项目设计
  新建项目
  1、文件-》新建-》RT-Thread项目
  2、选择基于开发板-》CPK-RA2L1 填入项目名称,点击完成,就创建好了工程。
  3、给RA Smart Configurator设置FSP3.5.0的路径:
  4、打开RT-Thread settings添加hs3003软包:
  5、打开I2c,配置P407、P408为I2C的SDA、SCL:
  6、修改sensor_renesas_hs300x.c为如下内容:
  * Copyright (c) 2006-2018, RT-Thread Development Team
  * SPDX-License-Identifier: Apache-2.0
  * Change Logs:
  * Date Author Notes
  * 2020-11-03 flybreak the first version
  #include 《stdint.h》
  #include 《stdlib.h》
  #include “sensor_renesas_hs300x.h”
  #define DBG_TAG “sensor.renesas.hs300x”
  #define DBG_LVL DBG_INFO
  #include 《rtdbg.h》
  #define SENSOR_TEMP_RANGE_MAX (80)
  #define SENSOR_TEMP_RANGE_MIN (-10)
  #define SENSOR_HUMI_RANGE_MAX (100)
  #define SENSOR_HUMI_RANGE_MIN (0)
  /* Definitions of Mask Data for A/D data */
  #define RM_HS300X_MASK_HUMIDITY_UPPER_0X3F (0x3F)
  #define RM_HS300X_MASK_TEMPERATURE_LOWER_0XFC (0xFC)
  #define RM_HS300X_MASK_STATUS_0XC0 (0xC0)
  /* Definitions for Status Bits of A/D Data */
  #define RM_HS300X_DATA_STATUS_VALID (0x00) // Status-bit: Valid data
  /* Definitions for Calculation */
  #define RM_HS300X_CALC_STATIC_VALUE (16383.0F)
  #define RM_HS300X_CALC_HUMD_VALUE_100 (100.0F)
  #define RM_HS300X_CALC_TEMP_C_VALUE_165 (165.0F)
  #define RM_HS300X_CALC_TEMP_C_VALUE_40 (40.0F)
  #define RM_HS300X_CALC_DECIMAL_VALUE_100 (100.0F)
  struct hs300x_device
  struct rt_i2c_bus_device *i2c;
  uint8_t addr;
  struct hs300x_device temp_humi_dev;
  static rt_err_t _hs300x_init(struct rt_sensor_intf *intf)
  temp_humi_dev.i2c = rt_i2c_bus_device_find(intf-》dev_name);
  temp_humi_dev.addr = (uint8_t)intf-》user_data;
  if (temp_humi_dev.i2c == RT_NULL)
  return -RT_ERROR;
  return RT_EOK;
  int hs300x_read_data(struct hs300x_device* dev, float *humi_f, float *temp_f)
  uint8_t r_buf[4] = {0};
  uint16_t humi, temp;
  float tmp_f = 0.0;
  struct rt_i2c_msg msgs;
  msgs.addr = dev-》addr;
  msgs.flags = RT_I2C_WR;
  msgs.buf = 0;
  msgs.len = 0;
  if (rt_i2c_transfer(dev-》i2c, &msgs, 1) != 1)
  LOG_E(“mr error!n”);
  return -1;
  msgs.flags = RT_I2C_RD;
  msgs.buf = r_buf;
  msgs.len = 4;
  __retry:
  if (rt_i2c_transfer(dev-》i2c, &msgs, 1) == 1)
  LOG_D(“%x,%x,%x,%xn”, r_buf[0], r_buf[1], r_buf[2], r_buf[3]);
  LOG_D(“state:%xn”, r_buf[0] & RM_HS300X_MASK_STATUS_0XC0);
  if ((r_buf[0] & RM_HS300X_MASK_STATUS_0XC0) != RM_HS300X_DATA_STATUS_VALID)
  rt_thread_mdelay(100);
  goto __retry;
  humi = (r_buf[0] & RM_HS300X_MASK_HUMIDITY_UPPER_0X3F) 《《 8 | r_buf[1];
  temp = (r_buf[2] 《《 8 | (r_buf[3] & RM_HS300X_MASK_TEMPERATURE_LOWER_0XFC)) 》》 2;
  tmp_f = (float)humi;
  tmp_f = (tmp_f * RM_HS300X_CALC_HUMD_VALUE_100) / RM_HS300X_CALC_STATIC_VALUE;
  if (humi_f)
  *humi_f = tmp_f;
  tmp_f = (float)temp;
  tmp_f = ((tmp_f * RM_HS300X_CALC_TEMP_C_VALUE_165) / RM_HS300X_CALC_STATIC_VALUE) - RM_HS300X_CALC_TEMP_C_VALUE_40;
  if (temp_f)
  *temp_f = tmp_f;
  return 0;
  else {
  LOG_E(“read error!n”);
  return -1;
  float hs300x_read_temperature(struct hs300x_device* dev)
  float temp;
  if (hs300x_read_data(dev, NULL, &temp) == 0)
  return temp;
  return 0;
  float hs300x_read_humidity(struct hs300x_device* dev)
  float humi;
  if (hs300x_read_data(dev, &humi, NULL) == 0)
  return humi;
  return 0;
  static rt_size_t _hs300x_polling_get_data(rt_sensor_t sensor, struct rt_sensor_data *data)
  float temperature_x10, humidity_x10;
  if (sensor-》info.type == RT_SENSOR_CLASS_TEMP)
  temperature_x10 = 10 * hs300x_read_temperature(&temp_humi_dev);
  data-》data.temp = (rt_int32_t)temperature_x10;
  data-》timestamp = rt_sensor_get_ts();
  else if (sensor-》info.type == RT_SENSOR_CLASS_HUMI)
  humidity_x10 = 10 * hs300x_read_humidity(&temp_humi_dev);
  data-》data.humi = (rt_int32_t)humidity_x10;
  return 1;
  static rt_size_t hs300x_fetch_data(struct rt_sensor_device *sensor, void *buf, rt_size_t len)
  RT_ASSERT(buf);
  if (sensor-》config.mode == RT_SENSOR_MODE_POLLING)
  return _hs300x_polling_get_data(sensor, buf);
  else
  return 0;
  static rt_err_t hs300x_control(struct rt_sensor_device *sensor, int cmd, void *args)
  rt_err_t result = RT_EOK;
  return result;
  static struct rt_sensor_ops sensor_ops =
  hs300x_fetch_data,
  hs300x_control
  int rt_hw_hs300x_init(const char *name, struct rt_sensor_config *cfg)
  rt_int8_t result;
  rt_sensor_t sensor_temp = RT_NULL, sensor_humi = RT_NULL;
  /* temperature sensor register */
  sensor_temp = rt_calloc(1, sizeof(struct rt_sensor_device));
  if (sensor_temp == RT_NULL)
  return -1;
  sensor_temp-》info.type = RT_SENSOR_CLASS_TEMP;
  sensor_temp-》info.vendor = RT_SENSOR_VENDOR_UNKNOWN;
  sensor_temp-》info.model = “hs300x”;
  sensor_temp-》info.unit = RT_SENSOR_UNIT_DCELSIUS;
  sensor_temp-》info.intf_type = RT_SENSOR_INTF_I2C;
  sensor_temp-》info.range_max = SENSOR_TEMP_RANGE_MAX;
  sensor_temp-》info.range_min = SENSOR_TEMP_RANGE_MIN;
  sensor_temp-》info.period_min = 5;
  rt_memcpy(&sensor_temp-》config, cfg, sizeof(struct rt_sensor_config));
  sensor_temp-》ops = &sensor_ops;
  result = rt_hw_sensor_register(sensor_temp, name, RT_DEVICE_FLAG_RDONLY, RT_NULL);
  if (result != RT_EOK)
  LOG_E(“device register err code: %d”, result);
  goto __exit;
  /* humidity sensor register */
  sensor_humi = rt_calloc(1, sizeof(struct rt_sensor_device));
  if (sensor_humi == RT_NULL)
  return -1;
  sensor_humi-》info.type = RT_SENSOR_CLASS_HUMI;
  sensor_humi-》info.vendor = RT_SENSOR_VENDOR_UNKNOWN;
  sensor_humi-》info.model = “hs300x”;
  sensor_humi-》info.unit = RT_SENSOR_UNIT_PERMILLAGE;
  sensor_humi-》info.intf_type = RT_SENSOR_INTF_I2C;
  sensor_humi-》info.range_max = SENSOR_HUMI_RANGE_MAX;
  sensor_humi-》info.range_min = SENSOR_HUMI_RANGE_MIN;
  sensor_humi-》info.period_min = 5;
  rt_memcpy(&sensor_humi-》config, cfg, sizeof(struct rt_sensor_config));
  sensor_humi-》ops = &sensor_ops;
  result = rt_hw_sensor_register(sensor_humi, name, RT_DEVICE_FLAG_RDONLY, RT_NULL);
  goto __exit;
  _hs300x_init(&cfg-》intf);
  return RT_EOK;
  __exit:
  if (sensor_temp)
  rt_free(sensor_temp);
  if (sensor_humi)
  rt_free(sensor_humi);
  return -RT_ERROR;
  #define HS300X_I2C_BUS “i2c1”
  int rt_hw_hs300x_port(void)
  struct rt_sensor_config cfg;
  cfg.intf.dev_name = HS300X_I2C_BUS;
  cfg.intf.user_data = (void *)HS300X_I2C_ADDR;
  rt_hw_hs300x_init(“hs300x”, &cfg);
  return RT_EOK;
  INIT_APP_EXPORT(rt_hw_hs300x_port);
  6、修改hal_entry.c为如下内容:
  * Copyright (c) 2006-2021, RT-Thread Development Team
  * Change Logs:
  * Date Author Notes
  * 2021-10-10 Sherman first version
  #include 《rtthread.h》
  #include “hal_data.h”
  #include 《rtdevice.h》
  #define LED1_PIN “P502” /* Onboard LED pins */
  #define USER_INPUT “P004”
  extern struct hs300x_device temp_humi_dev;
  void hal_entry(void)
  float temp_f,humi_f;
  rt_kprintf(“nHello RT-Thread!n”);
  rt_uint32_t led1_pin = rt_pin_get(LED1_PIN);
  while (1)
  rt_pin_write(led1_pin, PIN_HIGH);
  rt_thread_mdelay(500);
  rt_pin_write(led1_pin, PIN_LOW);
  hs300x_read_data(&temp_humi_dev, &humi_f, &temp_f);
  rt_kprintf(“HUMI: %d.%2dn”, (int)humi_f, (int)(humi_f*100)%100);
  rt_kprintf(“HUMI: %d.%2dn”, (int)temp_f, (int)(temp_f*100)%100);
  void irq_callback_test(void *args)
  rt_kprintf(“n IRQ03 triggered n”);
  void icu_sample(void)
  /* init */
  rt_uint32_t pin = rt_pin_get(USER_INPUT);
  rt_kprintf(“n pin number : 0x%04X n”, pin);
  rt_err_t err = rt_pin_attach_irq(pin, PIN_IRQ_MODE_RISING, irq_callback_test, RT_NULL);
  if (RT_EOK != err)
  rt_kprintf(“n attach irq failed. n”);
  err = rt_pin_irq_enable(pin, PIN_IRQ_ENABLE);
  if (RT_EOK != err)
  rt_kprintf(“n enable irq failed. n”);
  MSH_CMD_EXPORT(icu_sample, icu sample);
  实现效果为:
  【小结】
  这节主要是新建基础工程,并且添加hs3003的软件包。实现温度、湿度的采集。
原作者:Lu_盼盼
更多回帖
