乐鑫技术交流
直播中
石飞鹏
8年用户 1085经验值
私信 关注
[问答]
使用coded PHY来做Advertising的问题求解
我要使用 ESP32-C3 来做一个 BLE Long Range 广播封包,我使用 multi_adv_demo.c 来修改,程序档案如下,
Code: [Select all] [Expand/Collapse]
  • #define FUNC_SEND_WAIT_SEM(func, sem) do {
  •         esp_err_t __err_rc = (func);
  •         if (__err_rc != ESP_OK) {
  •             ESP_LOGE(LOG_TAG, "%s, message send fail, error = %d", __func__, __err_rc);
  •         xSemaphoreTake(sem, portMAX_DELAY);
  • } while(0);
  • static SemaphoreHandle_t test_sem = NULL;
  • esp_ble_gap_ext_adv_params_t legacy_adv_params = {
  •     .type = ESP_BLE_GAP_SET_EXT_ADV_PROP_LEGACY_IND,
  •     .interval_min = 320,
  •     .interval_max = 640,
  •     .channel_map = ADV_CHNL_ALL,
  •     .filter_policy = ADV_FILTER_ALLOW_SCAN_ANY_CON_ANY,
  •     .primary_phy = ESP_BLE_GAP_PHY_1M,
  •     .max_skip = 0,
  •     .secondary_phy = ESP_BLE_GAP_PHY_1M,
  •     .sid = 0,
  •     .scan_req_notif = false,
  •     .own_addr_type = BLE_ADDR_TYPE_PUBLIC,
  • esp_ble_gap_ext_adv_params_t ext_adv_params_coded = {
  •     .type = ESP_BLE_GAP_SET_EXT_ADV_PROP_SCANNABLE,
  •     .interval_min = 640,
  •     .interval_max = 960,
  •     .primary_phy = ESP_BLE_GAP_PHY_CODED,
  •     .max_skip = 0,
  •     .secondary_phy = ESP_BLE_GAP_PHY_CODED,
  •     .sid = 1,
  • static uint8_t legacy_adv_data[ = {
  •         0x02, 0x01, 0x06,
  •         0x02, 0x0a, 0xeb,
  •         0x14, 0x09, 'E', 'S', 'P', '_', 'M', 'U', 'L', 'T', 'I', '_', 'A',
  •         'D', 'V', '_', 'C', 'O', 'D', 'E', 'D'
  • static uint8_t legacy_scan_rsp_data[ = {
  •         0x02, 0x01, 0x06,
  •         0x02, 0x0a, 0xeb,
  •         0x15, 0x09, 'E', 'S', 'P', '_', 'M', 'U', 'L', 'T', 'I', '_', 'A',
  •         'D', 'V', '_', 'L', 'E', 'G', 'A', 'C', 'Y'
  • static uint8_t raw_scan_rsp_data_coded[ = {
  •         0x02, 0x01, 0x06,
  •         0x02, 0x0a, 0xeb,
  • static esp_ble_gap_ext_adv_t ext_adv[4 = {
  •     // instance, duration, peroid
  •     [0 = {0, 0, 0},
  •     [1 = {1, 0, 0},
  • static void gap_event_handler(esp_gap_ble_cb_event_t event, esp_ble_gap_cb_param_t *param)
  •     switch (event) {
  •     case ESP_GAP_BLE_EXT_ADV_SET_RAND_ADDR_COMPLETE_EVT:
  •         xSemaphoreGive(test_sem);
  •         ESP_LOGI(LOG_TAG, "ESP_GAP_BLE_EXT_ADV_SET_RAND_ADDR_COMPLETE_EVT, status %d", param->ext_adv_set_rand_addr.status);
  •         break;
  •     case ESP_GAP_BLE_EXT_ADV_SET_PARAMS_COMPLETE_EVT:
  •         ESP_LOGI(LOG_TAG, "ESP_GAP_BLE_EXT_ADV_SET_PARAMS_COMPLETE_EVT, status %d", param->ext_adv_set_params.status);
  •         break;
  •     case ESP_GAP_BLE_EXT_ADV_DATA_SET_COMPLETE_EVT:
  •         ESP_LOGI(LOG_TAG, "ESP_GAP_BLE_EXT_ADV_DATA_SET_COMPLETE_EVT, status %d", param->ext_adv_data_set.status);
  •         break;
  •     case ESP_GAP_BLE_EXT_SCAN_RSP_DATA_SET_COMPLETE_EVT:
  •         ESP_LOGI(LOG_TAG, "ESP_GAP_BLE_EXT_SCAN_RSP_DATA_SET_COMPLETE_EVT, status %d", param->scan_rsp_set.status);
  •         break;
  •     case ESP_GAP_BLE_EXT_ADV_START_COMPLETE_EVT:
  •         ESP_LOGI(LOG_TAG, "ESP_GAP_BLE_EXT_ADV_START_COMPLETE_EVT, status %d", param->ext_adv_start.status);
  •         break;
  •     case ESP_GAP_BLE_EXT_ADV_STOP_COMPLETE_EVT:
  •         ESP_LOGI(LOG_TAG, "ESP_GAP_BLE_EXT_ADV_STOP_COMPLETE_EVT, status %d", param->ext_adv_stop.status);
  •         break;
  •     default:
  •         break;
  • void app_main(void)
  •     esp_err_t ret;
  •     // Initialize NVS.
  •     ret = nvs_flash_init();
  •     if (ret == ESP_ERR_NVS_NO_FREE_PAGES || ret == ESP_ERR_NVS_NEW_VERSION_FOUND) {
  •         ESP_ERROR_CHECK(nvs_flash_erase());
  •     ESP_ERROR_CHECK( ret );
  •     ESP_ERROR_CHECK(esp_bt_controller_mem_release(ESP_BT_MODE_CLASSIC_BT));
  •     esp_bt_controller_config_t bt_cfg = BT_CONTROLLER_INIT_CONFIG_DEFAULT();
  •     ret = esp_bt_controller_init(&bt_cfg);
  •     if (ret) {
  •         ESP_LOGE(LOG_TAG, "%s initialize controller failed: %sn", __func__, esp_err_to_name(ret));
  •         return;
  •     ret = esp_bt_controller_enable(ESP_BT_MODE_BLE);
  •     if (ret) {
  •         ESP_LOGE(LOG_TAG, "%s enable controller failed: %sn", __func__, esp_err_to_name(ret));
  •         return;
  •     ret = esp_bluedroid_init();
  •     if (ret) {
  •         ESP_LOGE(LOG_TAG, "%s init bluetooth failed: %sn", __func__, esp_err_to_name(ret));
  •         return;
  •     ret = esp_bluedroid_enable();
  •     if (ret) {
  •         ESP_LOGE(LOG_TAG, "%s enable bluetooth failed: %sn", __func__, esp_err_to_name(ret));
  •         return;
  •     ret = esp_ble_gap_register_callback(gap_event_handler);
  •     if (ret){
  •         ESP_LOGE(LOG_TAG, "gap register error, error code = %x", ret);
  •         return;
  •     vTaskDelay(200 / portTICK_PERIOD_MS);
  •     test_sem = xSemaphoreCreateBinary();
  •     // 1M phy legacy adv, ADV_IND
  •     FUNC_SEND_WAIT_SEM(esp_ble_gap_ext_adv_set_params(0, &legacy_adv_params), test_sem);
  •     FUNC_SEND_WAIT_SEM(esp_ble_gap_config_ext_adv_data_raw(0, sizeof(legacy_adv_data), &legacy_adv_data[0), test_sem);
  •     FUNC_SEND_WAIT_SEM(esp_ble_gap_config_ext_scan_rsp_data_raw(0, sizeof(legacy_scan_rsp_data), &legacy_scan_rsp_data[0), test_sem);
  •     // coded phy extend adv, Connectable advertising
  •     FUNC_SEND_WAIT_SEM(esp_ble_gap_ext_adv_set_params(1, &ext_adv_params_coded), test_sem);
  • //    FUNC_SEND_WAIT_SEM(esp_ble_gap_config_ext_adv_data_raw(1, sizeof(legacy_adv_data), &legacy_adv_data[0]), test_sem);
  •     FUNC_SEND_WAIT_SEM(esp_ble_gap_config_ext_scan_rsp_data_raw(1, sizeof(raw_scan_rsp_data_coded), &raw_scan_rsp_data_coded[0), test_sem);
  •     // start all adv
  •     FUNC_SEND_WAIT_SEM(esp_ble_gap_ext_adv_start(2, &ext_adv[0), test_sem);
  •     return;
执行时 log 显示程序正确执行,我也于 Sniffer 上看见了 Long Range 格式的 SCAN RSP 封包。
I (641) MULTI_ADV_DEMO: ESP_GAP_BLE_EXT_ADV_SET_PARAMS_COMPLETE_EVT, status 0
I (641) MULTI_ADV_DEMO: ESP_GAP_BLE_EXT_ADV_DATA_SET_COMPLETE_EVT, status 0
I (641) MULTI_ADV_DEMO: ESP_GAP_BLE_EXT_SCAN_RSP_DATA_SET_COMPLETE_EVT, status 0
I (651) MULTI_ADV_DEMO: ESP_GAP_BLE_EXT_ADV_SET_PARAMS_COMPLETE_EVT, status 0
I (661) MULTI_ADV_DEMO: ESP_GAP_BLE_EXT_SCAN_RSP_DATA_SET_COMPLETE_EVT, status 0
I (671) MULTI_ADV_DEMO: ESP_GAP_BLE_EXT_ADV_START_COMPLETE_EVT, status 0
我现在想要将 Long Range 广播封包改成 ADV 封包,但于
却出现了问题,LOG 如下
E (661) BT_BTM: LE EA SetAdvData: cmd err=0x12
I (661) MULTI_ADV_DEMO: ESP_GAP_BLE_EXT_ADV_DATA_SET_COMPLETE_EVT, status 7
I (671) MULTI_ADV_DEMO: ESP_GAP_BLE_EXT_SCAN_RSP_DATA_SET_COMPLETE_EVT, status 0
I (681) MULTI_ADV_DEMO: ESP_GAP_BLE_EXT_ADV_START_COMPLETE_EVT, status 0
请问我该如何修改呢?
更多回帖
