ST意法半导体
直播中
李超
7年用户 1349经验值
私信 关注
[问答]
HAL_UARTEx_RxEventCallback函数无法在L0上调用咋办
我正在尝试使用 DMA 进行 USART 通信。使用 HAL 库编写的代码可以在 STM32F0 上运行,但不能在 L0 上运行。我在终端获得不相关的数据。
此外,HAL_UARTEx_RxEventCallback 函数可以在 F0 上调用,但不能在 L0 上调用。
这是我的一些代码。
我哪里错了?
  • /* USER CODE BEGIN PV */
  • #define RxBuf_SIZE   10
  • #define MainBuf_SIZE 10
  • char        TxBuffer[4]={0x12,0x34,0x56,0x78};
  • uint8_t        RxBuffer[RxBuf_SIZE],MainBuf[MainBuf_SIZE];
  • char str[24];
  • int sayi=0;
  • uint16_t oldPos = 0;
  • uint16_t newPos = 0;
  • int isOK = 0;
  • /* USER CODE END PV */
  • /* Private function prototypes -----------------------------------------------*/
  • void SystemClock_Config(void);
  • /* USER CODE BEGIN PFP */
  • /* USER CODE END PFP */
  • /* Private user code ---------------------------------------------------------*/
  • /* USER CODE BEGIN 0 */
  • void HAL_UART_TxHalfCpltCallback(UART_HandleTypeDef *huart)
  •         __NOP();
  • void HAL_UARTEx_RxEventCallback(UART_HandleTypeDef *huart, uint16_t Size)
  •         if (huart->Instance == USART1)
  •                 oldPos = newPos;  // Update the last position before copying new data
  •                 /* If the data in large and it is about to exceed the buffer size, we have to route it to the start of the buffer
  •                  * This is to maintain the circular buffer
  •                  * The old data in the main buffer will be overlapped
  •                 if (oldPos+Size > MainBuf_SIZE)  // If the current position + new data size is greater than the main buffer
  •                         uint16_t datatocopy = MainBuf_SIZE-oldPos;  // find out how much space is left in the main buffer
  •                         memcpy ((uint8_t *)MainBuf+oldPos, RxBuffer, datatocopy);  // copy data in that remaining space
  •                         oldPos = 0;  // point to the start of the buffer
  •                         memcpy ((uint8_t *)MainBuf, (uint8_t *)RxBuffer+datatocopy, (Size-datatocopy));  // copy the remaining data
  •                         newPos = (Size-datatocopy);  // update the position
  •                 /* if the current position + new data size is less than the main buffer
  •                  * we will simply copy the data into the buffer and update the position
  •                 else
  •                         memcpy ((uint8_t *)MainBuf+oldPos, RxBuffer, Size);
  •                         newPos = Size+oldPos;
  •                 for(int i=Size;i                        RxBuffer=0;
  •                 /* start the DMA again */
  •                 HAL_UARTEx_ReceiveToIdle_DMA(&huart1, (uint8_t *) RxBuffer, RxBuf_SIZE);
  •   __HAL_DMA_DISABLE_IT(&hdma_usart1_rx, DMA_IT_HT);
  • /* USER CODE BEGIN 2 */
  •         HAL_UART_Transmit_DMA(&huart1,(uint8_t*)TxBuffer,sizeof(TxBuffer));
  •         HAL_UARTEx_ReceiveToIdle_DMA(&huart1, RxBuffer, RxBuf_SIZE);
  •   /* USER CODE END 2 */
  •   /* Infinite loop */
  •   /* USER CODE BEGIN WHILE */
  •   while (1)
  •     /* USER CODE END WHILE */
  •     /* USER CODE BEGIN 3 */
  •                 HAL_Delay(20);
  •   /* USER CODE END 3 */
回帖(1)
王红梅
2022-12-23 09:45:32
我从终端发送 0x77,STM 接收 0x44。终端发送0x7F,STM取0x40
这听起来像是倒置的信号。
您是否使用任何电平转换器,'F0 和 'L0 情况不同?
如果不是,读出并比较 USART_CR2.RXINV 位。
举报
更多回帖
