ST意法半导体
直播中
贾熹
8年用户 1687经验值
私信 关注
[问答]
STM32L476JG为什么没有进入DMA回调?
有一个文件,我正在尝试将其传输到 SAI2。由于某些原因 ????我没有进入 DMA 回调。DMA 处于正常模式。任何人都可以阐明这一点吗?
  •   /* USER CODE BEGIN 2 */
  •   HAL_DMA_RegisterCallback(&hdma_sai2_a, HAL_DMA_XFER_CPLT_CB_ID, &DMA_XferCmplt_Callback);
  •   /* USER CODE END 2 */
  •   /* Infinite loop */
  •   /* USER CODE BEGIN WHILE */
  •   while (1)
  •           if (ISR.DMA_TxCmplt)
  •                   ISR.DMA_TxCmplt = F;
  •                    * after each DMA check if high current
  •                    * if NOT then disable SAI dma
  •                         if (adcValue[1] < (HIGH_CURRENT))
  •                                 hsai_BlockA2.Instance->CR1 &= ~SAI_xCR1_DMAEN;
  •           if (ISR.A_ConversionComplete)
  •                   ISR.A_ConversionComplete = F;
  •                    * checks to see if actuator has
  •                    * bottomed out due to high current
  •                   if (adcValue[1] > (HIGH_CURRENT))
  •                           hsai_BlockA2.Instance->CR1 |= SAI_xCR1_DMAEN;
  •                            * if we are engaging and high current
  •                            * shut off motor drive and alarm
  •                           if (ISR.Sw_EngageFlag)
  •                                   HAL_GPIO_WritePin(MotorCntrlA_GPIO_Port, MotorCntrlA_Pin, GPIO_PIN_RESET);
  •                                   PlayAudio(a4_tone, a4_tone_length);
  •                                   ISR.Sw_EngageFlag = F;
  •                            * if we are dis-engaging and high current
  •                           if (ISR.Sw_DisengageFlag)
  •                                   HAL_GPIO_WritePin(MotorCntrlB_GPIO_Port, MotorCntrlB_Pin, GPIO_PIN_RESET);
  •                                   ISR.Sw_DisengageFlag = F;
  •                           //dma buffer created by PlayAudio to audio chip
  •                           HAL_DMA_Start_IT(&hdma_sai2_a, (uint32_t)playout_buffer, (uint32_t)&hsai_BlockA2.Instance->DR, a4_tone_length);
  • void PlayAudio(const int16_t *buffer, int32_t n_samples)
  •         for (int i=0; i < n_samples; i++) {                // Duplicate each sample.  The SAI insists on 2 channels of mono
  •                 playout_buffer[i*2] = buffer * LEVEL_REDUCtiON;
  •                 playout_buffer[i*2+1] = buffer * LEVEL_REDUCTION;
  • void DMA_XferCmplt_Callback(DMA_HandleTypeDef *hdma)
  •         if (hdma == &hdma_sai2_a)
  •                 ISR.DMA_TxCmplt = T;
更多回帖
