启动卡在了starting kernel阶段.
完全根据官方原理图设计的板子,只外接了一个I2C设备到I2C-0口上.部分芯片没货有更改 下面是打印信息
DDR version 1.16 20190528
In
DDR3
333MHz
Bus Width=32 Col=10 Bank=8 Row=15/15 CS=2 Die Bus-Width=16 Size=2048MB
ddrconfig:6
OUT
Boot1 Release Time: May 13 2019 17:34:36, version: 2.50
ChipType = 0x11, 233
mmc2:cmd19,100
SdmmcInit=2 0
BootCapSize=2000
UserCapSize=14910MB
FwPartOffset=2000 , 2000
SdmmcInit=0 NOT PRESENT
StorageInit ok = 11388
Raw SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit ret = 0, SecureMode = 0
atags_set_bootdev: ret:(0)
GPT part: 0, name: uboot, start:0x4000, size:0x2000
GPT part: 1, name: trust, start:0x6000, size:0x2000
GPT part: 2, name: misc, start:0x8000, size:0x2000
GPT part: 3, name: boot, start:0xa000, size:0x10000
GPT part: 4, name: recovery, start:0x1a000, size:0x10000
GPT part: 5, name: backup, start:0x2a000, size:0x10000
GPT part: 6, name: rootfs, start:0x5a000, size:0x588400
GPT part: 7, name: userdata, start:0x5e2400, size:0x173cbdf
find part:uboot OK. first_lba:0x4000.
find part:trust OK. first_lba:0x6000.
LoadTrust Addr:0x6000
No find bl30.bin
Load uboot, ReadLba = 4000
Load OK, addr=0x200000, size=0xd1a30
RunBL31 0x40000
INFO: Preloader serial: 2
NOTICE: BL31: v1.3(release):3be52e9
NOTICE: BL31: Built : 14:51:38, Nov 3 2020
NOTICE: BL31:Rockchip release version: v1.3
INFO: ARM GICv2 driver initialized
INFO: Using opteed sec cpu_context!
INFO: boot cpu mask: 1
INFO: plat_rockchip_pmu_init: pd status 0xe
INFO: BL31: Initializing runtime services
INFO: BL31: Initializing BL32
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-266-gee81607c #3 Mon Aug 17 09:29:38 UTC 2020 aarch64)
INF [0x0] TEE-CORE:init_primary_helper:338: Release version: 1.4
INF [0x0] TEE-CORE:init_teecore:83: teecore inits done
INFO: BL31: Preparing for EL3 exit to normal world
INFO: Entry point address = 0x200000
INFO: SPSR = 0x3c9
U-Boot 2017.09-gc56bc3a030 #sterben (Sep 02 2022 - 01:28:27 -0700)
Model: Firefly ROC-RK3328-CC
PreSerial: 2
DRAM: 2 GiB
Sysmem: init
Relocation Offset: 7dbf5000, fdt: 7bdea578
Using default environment
rksdmmc@ff500000: 1, rksdmmc@ff520000: 0
Bootdev(atags): mmc 0
MMC0: High Speed, 52Mhz
PartType: EFI
boot mode: recovery (misc)
Found DTB in recovery part
DTB: rk-kernel.dtb
HASH(s): OK
Android header version 0
use default hdmi phy table
Warn: can't find connect driver
In: serial
Out: serial
Err: serial
Model: Firefly ROC-RK3328-PC
Rockchip UBOOT DRM driver version: v1.0.1
CLK: (sync kernel. arm: enter 600000 KHz, init 600000 KHz, kernel 0N/A)
apll 400000 KHz
dpll 664000 KHz
cpll 1200000 KHz
gpll 491009 KHz
npll 600000 KHz
armclk 600000 KHz
aclk_bus 150000 KHz
hclk_bus 75000 KHz
pclk_bus 75000 KHz
aclk_peri 150000 KHz
hclk_peri 75000 KHz
pclk_peri 75000 KHz
Net:
Warning: ethernet@ff540000 (eth0) using random MAC address - 72:d7:3a:68:64:1c
eth0: ethernet@ff540000
Hit key to stop autoboot('CTRL+C'): 0
ANDROID: reboot reason: "recovery"
Booting IMAGE kernel at 0x00280000 with fdt at 0x08300000...
Fdt Ramdisk skip relocation
Kernel load addr 0x00280000 size 21393 KiB
RAM disk load addr 0x0a200000 size 8762 KiB
Booting using the fdt blob at 0x8300000
XIP Kernel Image from 0x00280000 to 0x00280000 ... OK
Using Device Tree in place at 0000000008300000, end 00000000083157e6
No file: logo_kernel.bmp
Adding bank: 0x00200000 - 0x08400000 (size: 0x08200000)
Adding bank: 0x0a200000 - 0x80000000 (size: 0x75e00000)
Total: 4125.575 ms
Starting kernel ...
更多回帖
