瑞芯微Rockchip开发者社区
直播中
斯克迪亚
13年用户 415经验值
私信 关注
[问答]
温度对GPU频率的影响是什么?
温度对GPU频率的影响是什么?
回帖(1)
胡毅秉
2022-3-10 10:49:00
有两处温度设定会对GPU有影响:
1. rk3288.dtsi
clk_gpu_dvfs_table: clk_gpu {
    operating-points = <
        /* KHz uV */
        200000 1200000
        300000 1200000
        400000 1200000
    channel = <1>;
    tsadc-ch = <2>;
    temp-limit-enable = <0>;
    target-temp = <90>;
    min_temp_limit = <200>;
    normal-temp-limit = <
    /*delta-temp delta-freq*/
        3   50000
        6   150000
        15  250000
    regu-mode-table = <
        /*freq mode*/
        200000     4
        0          3
    regu-mode-en = <0>;
    status = "okay";
当温度超过target-temp后,会按照normal-temp-limit此table中的delta_temp来降低当前的frequency为cur_freq - delta_freq, 最低值不能小于min_temp_limit. 此值用于和当前要设置的target_freq比较,如果target_freq比cur_freq - delta_freq大,那么就设置成cur_freq - delta_freq.
由于temp-limit-enable的值是0,所以此功能默认是关闭的,根据情况决定是否使能.
2. mali_kbase_dvfs.c:
static void mali_dvfs_event_proc(struct work_struct *w)
    int ret = 0;
    struct rk_dvfs_t *dvfs = work_to_dvfs(w);
    int temp = rockchip_tsadc_get_temp(1, 0);
    if (is_overheated(dvfs)) {
        if (could_jump_down(dvfs)) {
            I("to jump down for overheated, temp:%d.",
              dvfs->temp);
            ret = jump_down_actually(dvfs);
            if (ret)
                E("fail to jump down, ret:%d.", ret);
        } else {
            W("overheated! temp:%d, but can't jump down anymore.",
              dvfs->temp);
        dvfs->temp = 0;
        goto EXIT;
通过rockchip_tsadc_get_temp()读取,如果温度过高(is_overheated()),这里的阀值设置的是110°,
#define TEMP_UPPER_LIMIT (110)
那么就通过jump_down_actually()降低频率.
举报
更多回帖
