瑞芯微Rockchip开发者社区
直播中
李明
7年用户 1299经验值
私信 关注
[问答]
RK3399/RK3328 Android10.0预置kodi打开提示找不到so库是什么原因
RK3399/RK3328 Android10.0预置kodi打开提示找不到so库是什么原因?怎样去解决呢?
回帖(1)
杨文英
2022-3-9 13:44:20
测试平台
Platform: RK3399/RK3328
OS: Android10.0
说明
rk提供了几种预置apk的方案给到客户,具体的集成方案可见源码下文档(RKDocs/android/Rockchip_Introduction_Android_Application_Preinstallation_CN&EN.pdf)
测试发现预置其他apk正常,但是预置kodi打开提示找不到so库
分析
查看源码可知,rk的preinstall是在frameworks/base/services/core/java/com/android/server/pm/PackageManagerService.java中做了处理
private static void setNativeLibraryPaths(PackageParser.Package pkg, File appLib32InstallDir, int scanFlags) {
} else {
            // Cluster install
            if ((scanFlags & SCAN_AS_PREBUNDLED_DIR) != 0
                || (scanFlags & SCAN_AS_PREINSTALL) != 0) {
                // mAppLib32InstallDir is the directory /data/app-lib which is used to store native
                // libs for apps from the system paritition.  It isn't really specific to 32bit info
                // any way except for the variable name, the system will use the primary/secondary
                // ABI computed below.
                info.primaryCpuAbi = "armeabi-v7a";
                info.nativeLibraryRootDir = new File(codeFile, LIB_DIR_NAME).getAbsolutePath();
                Log.d(TAG, info.primaryCpuAbi + " prebundled install " + info.nativeLibraryRootDir);
            } else {
            info.nativeLibraryRootRequiresIsa = true;
            info.nativeLibraryDir = new File(info.nativeLibraryRootDir,
                    getPrimaryInstructionSet(info)).getAbsolutePath();
            if (info.secondaryCpuAbi != null) {
                info.secondaryNativeLibraryDir = new File(info.nativeLibraryRootDir,
                        VMRuntime.getInstructionSet(info.secondaryCpuAbi)).getAbsolutePath();
他在这里指定了info.primaryCpuAbi = “armeabi-v7a”;
强制使用armv7的so库,但是kodi-arm64中只有arm64位的库无32位的.所以修改这里让其可以适配64位和32位即可,修改补丁如下:
      -info.primaryCpuAbi = "armeabi-v7a";
      +info.primaryCpuAbi = "arm64-v8a";
      +info.secondaryCpuAbi = "armeabi-v7a";
编译后测试OK。
举报
更多回帖
