单片机学习小组
直播中
jfsky
16年用户 510经验值
私信 关注
LED如何配置?
LED如何配置?
回帖(1)
高敏兰
2022-2-7 11:35:14
LED配置
代码位于hal_board_cfg.h文件中
TI开发板有4个LED灯,P1_0 P1_1 P1_4 P0_1,都是高电平有效ACTIVE_HIGH
宏定义BV(n)函数 1<<(n) 表示1左移的位数,即寄存器置1的位数
#if defined (HAL_BOARD_CC2530EB_REV17) && !defined (HAL_PA_LNA) &&
    !defined (HAL_PA_LNA_CC2590) && !defined (HAL_PA_LNA_SE2431L) &&
    !defined (HAL_PA_LNA_CC2592)
  #define HAL_NUM_LEDS            3
#elif defined (HAL_BOARD_CC2530EB_REV13) || defined (HAL_PA_LNA) ||
      defined (HAL_PA_LNA_CC2590)  || defined (HAL_PA_LNA_CC2592) ||
  #define HAL_NUM_LEDS            1
#else
  #error Unknown Board Indentifier
#endif
#define HAL_LED_BLINK_DELAY()   st( { volatile uint32 i; for (i=0; i<0x5800; i++) { }; } )
/* 1 - Green */
#define LED1_BV           BV(0)
#define LED1_SBIT         P1_0
#define LED1_DDR          P1DIR
#define LED1_POLARITY     ACTIVE_HIGH
  /* 2 - Red */
  #define LED2_BV           BV(1)
  #define LED2_SBIT         P1_1
  #define LED2_DDR          P1DIR
  #define LED2_POLARITY     ACTIVE_HIGH
  /* 3 - Yellow */
  #define LED3_BV           BV(4)
  #define LED3_SBIT         P1_4
  #define LED3_DDR          P1DIR
  #define LED3_POLARITY     ACTIVE_HIGH
#ifdef ENABLE_LED4_DISABLE_S1
  /* 4 - Orange */
  #define LED4_BV             BV(1)
  #define LED4_SBIT           P0_1
  #define LED4_DDR            P0DIR
  #define LED4_POLARITY       ACTIVE_HIGH
  #define LED4_SET_DIR()      do {LED4_DDR |= LED4_BV;} while (0)
#else
#endif
#endif
LED置位位于hal_led.h中
#define HAL_LED_1     0x01
#define HAL_LED_2     0x02
#define HAL_LED_3     0x04
#define HAL_LED_4     0x08
#define HAL_LED_ALL   (HAL_LED_1 | HAL_LED_2 | HAL_LED_3 | HAL_LED_4)
/* Modes */
#define HAL_LED_MODE_OFF     0x00
#define HAL_LED_MODE_ON      0x01
#define HAL_LED_MODE_BLINK   0x02
#define HAL_LED_MODE_FLASH   0x04
#define HAL_LED_MODE_TOGGLE  0x08
/* Defaults */
#define HAL_LED_DEFAULT_MAX_LEDS      4
#define HAL_LED_DEFAULT_DUTY_CYCLE    5
#define HAL_LED_DEFAULT_FLASH_COUNT   50
#define HAL_LED_DEFAULT_FLASH_TIME    1000
#LED初始化
代码位于两个位置hal_borad_cfg.h和hal_led.c
hal_borad_cfg.h中初始化方向位PxDIR,置1为输出
#define HAL_BOARD_INIT()
  HAL_TURN_OFF_LED1();
  LED1_DDR |= LED1_BV;
  HAL_TURN_OFF_LED2();
  LED2_DDR |= LED2_BV;
  HAL_TURN_OFF_LED3();
  LED3_DDR |= LED3_BV;
  HAL_TURN_OFF_LED4();
  LED4_SET_DIR();
hal_led.c中初始化LED为关状态
void HalLedInit (void)
#if (HAL_LED == TRUE)
  /* Initialize all LEDs to OFF */
  HalLedSet (HAL_LED_ALL, HAL_LED_MODE_OFF);
#endif /* HAL_LED */
#ifdef BLINK_LEDS
  /* Initialize sleepActive to FALSE */
  HalLedStatusControl.sleepActive = FALSE;
#endif
#LED驱动函数
hal_led.c文件中常用的有:
灯光模式选择函数HalLedSet(uint8 leds, uint8 mode )
灯光闪烁功能函数HalLedBlink( uint8 leds, uint8 numBlinks, uint8 percent, uint16 period)
还有:
用于blink的LED更新函数HalLedUpdate (void)
LED开关控制函数HalLedOnOff (uint8 leds, uint8 mode)
LED状态获取函数HalLedGetState ()
休眠前存储当前LED状态函数HalLedEnterSleep( void )
休眠后恢复LED状态函数HalLedExitSleep( void )
灯光模式选择函数HalLedSet()中mode的选择控制:
* @fn      HalLedSet
* @brief   Tun ON/OFF/TOGGLE given LEDs
* @param   led - bit mask value of leds to be turned ON/OFF/TOGGLE
*          mode - BLINK, FLASH, TOGGLE, ON, OFF
* @return  None
uint8 HalLedSet (uint8 leds, uint8 mode)
#if (defined (BLINK_LEDS)) && (HAL_LED == TRUE)
  uint8 led;
  HalLedControl_t *sts;
  switch (mode)
    case HAL_LED_MODE_BLINK:
      /* Default blink, 1 time, D% duty cycle */
      HalLedBlink (leds, 1, HAL_LED_DEFAULT_DUTY_CYCLE, HAL_LED_DEFAULT_FLASH_TIME);
      break;
    case HAL_LED_MODE_FLASH:
      /* Default flash, N times, D% duty cycle */
      HalLedBlink (leds, HAL_LED_DEFAULT_FLASH_COUNT, HAL_LED_DEFAULT_DUTY_CYCLE, HAL_LED_DEFAULT_FLASH_TIME);
      break;
    case HAL_LED_MODE_ON:
    case HAL_LED_MODE_OFF:
    case HAL_LED_MODE_TOGGLE:
      led = HAL_LED_1;
      leds &= HAL_LED_ALL;
      sts = HalLedStatusControl.HalLedControlTable;
      while (leds)
        if (leds & led)
          if (mode != HAL_LED_MODE_TOGGLE)
            sts->mode = mode;  /* ON or OFF */
          else
            sts->mode ^= HAL_LED_MODE_ON;  /* Toggle */
          HalLedOnOff (led, sts->mode);
          leds ^= led;
        led <<= 1;
        sts++;
      break;
    default:
      break;
#elif (HAL_LED == TRUE)
  LedOnOff(leds, mode);
#else
  // HAL LED is disabled, suppress unused argument warnings
  (void) leds;
  (void) mode;
#endif /* BLINK_LEDS && HAL_LED   */
  return ( HalLedState );
灯光闪烁函数HalLedBlink()
* @fn      HalLedBlink
* @brief   Blink the leds
* @param   leds       - bit mask value of leds to be blinked
*          numBlinks  - number of blinks
*          percent    - the percentage in each period where the led
*                       will be on
*          period     - length of each cycle in milliseconds
* @return  None
void HalLedBlink (uint8 leds, uint8 numBlinks, uint8 percent, uint16 period)
  uint8 led;
  if (leds && percent && period)
    if (percent < 100)
      led = HAL_LED_1;
      while (leds)
        if (leds & led)
          /* Store the current state of the led before going to blinking if not already blinking */
          if(sts->mode < HAL_LED_MODE_BLINK )
                  preBlinkState |= (led & HalLedState);
          sts->mode  = HAL_LED_MODE_OFF;                    /* Stop previous blink */
          sts->time  = period;                              /* Time for one on/off cycle */
          sts->onPct = percent;                             /* % of cycle LED is on */
          sts->todo  = numBlinks;                           /* Number of blink cycles */
          if (!numBlinks) sts->mode |= HAL_LED_MODE_FLASH;  /* Continuous */
          sts->next = osal_GetSystemClock();                /* Start now */
          sts->mode |= HAL_LED_MODE_BLINK;                  /* Enable blinking */
          leds ^= led;
        led <<= 1;
        sts++;
      // Cancel any overlapping timer for blink events
      osal_stop_timerEx(Hal_TaskID, HAL_LED_BLINK_EVENT);
      osal_set_event (Hal_TaskID, HAL_LED_BLINK_EVENT);
    else
      HalLedSet (leds, HAL_LED_MODE_ON);                    /* >= 100%, turn on */
  else
    HalLedSet (leds, HAL_LED_MODE_OFF);                     /* No on time, turn off */
  percent = (leds & HalLedState) ? HAL_LED_MODE_OFF : HAL_LED_MODE_ON;
  HalLedOnOff (leds, percent);                              /* Toggle */
#else
  (void) leds;
  (void) numBlinks;
  (void) percent;
  (void) period;
举报
更多回帖
