[make@archlinux tools]$ 。/phoenixMC
Version: v1.2.00815b(by notebook)
phoenixMC_u -A [debug flash address] (default: 0x00000000)
phoenixMC_u -b [baud rate] (default: 921600)
phoenixMC_u -B [flash debug bin file for write] (default: a.bin)
phoenixMC_u -c [com dev] (default: /dev/ttyUSB0)
phoenixMC_u -C [config file] (default: 。/settings.ini)
phoenixMC_u -d [debug log level] (default: 0)
phoenixMC_u -D [debug flash mode] (default: n=NULL)
phoenixMC_u -e [enable etf image] (default: 0)
phoenixMC_u -f [enable flash compat] (default: 1)
phoenixMC_u -g [enable combine images]
phoenixMC_u -G [combine image path] (default: combine_image.cimg)
phoenixMC_u -h [help msg]
phoenixMC_u -i [wlan image path] (default: xr-system.img)
phoenixMC_u -I [ETF image path] (default: xr-system_etf.img)
phoenixMC_u -l [log file path] (default: 。/log/log.txt)
phoenixMC_u -L [debug flash length] (default: 0x00000200)
phoenixMC_u -r [read and check after write] (default: 0)
phoenixMC_u -s [show image info]
phoenixMC_u -u [update changed blocks only] (default: 1)
phoenixMC_u -v [show version]
When it‘s upgrading, input ’stop‘ to stop it if you need.
--------------SETTING--------------
COM:/dev/ttyUSB0
Baud:921600
Log path:。/log/log.txt
Log level:0
Image path:。./out/xr_system.img
ETF image path:xr_system_etf.img
Read and check:NO
Update change only:YES
Program ETF image:NO
Use flash compat:YES
firmware information
bin version: 5
bin count: 6
No. ID sram_offs data_size next_section attribute private
1 0xA5FF5A00 0x00230000 0x000061C0 0x00008000 0x00000001 0xFFFFFFFFFFFFFFFFFC05FFFF
2 0xA5FE5A01 0x00201000 0x0000EDB0 0x00018000 0x00000001 0xFFFFFFFFFFFFFFFFFFFFFFFF
3 0xA5FD5A02 0xFFFFFFFF 0x0008B360 0x0010B800 0x00000002 0xFFFFFFFFFFFFFFFFFFFFFFFF
4 0xA5FA5A05 0xFFFFFFFF 0x00000910 0x0010C400 0x00000001 0xFFFFFFFFFFFFFFFFFFFFFFFF
5 0xA5F95A06 0xFFFFFFFF 0x00006394 0x00112800 0x00000001 0xFFFFFFFFFFFFFFFFFFFFFFFF
6 0xA5F85A07 0xFFFFFFFF 0x00000318 0xFFFFFFFF 0x00000001 0xFFFFFFFFFFFFFFFFFFFFFFFF
not Combined image!!
3%: Opening com.。.
magic:0x202C7373, 0x4D4F5242
Invalid response!
我只修改了/home/make/xr806_openharmony/device/xradio/xr806/
BUILD.gn
import(“//build/lite/config/subsystem/lite_subsystem.gni”)
import(“//build/lite/config/component/lite_component.gni”)
import(“//base/security/huks/build/config.gni”)
build_ext_component(“libSDK”) {
exec_path = rebase_path(“。”, root_build_dir)
outdir = rebase_path(“$root_out_dir”)
command = “。/build.sh ${outdir}”
deps = [
“//build/lite/:ohos”,
“//kernel/liteos_m:kernel”,
“os:liteos_glue”,
if (IsBootloader == “false”) {
deps += [
“adapter/hals:adapter”,
#“adapter/console:app_console”,
“ohosdemo:ohosdemo”
if (disable_huks_binary == true) {
deps += [
“//base/security/huks/frameworks/huks_lite:huks_sdk”,
group(“xr806”) {
COM:/dev/ttyUSB0
Baud:921600
Log level:0
Read and check:NO
bin version: 5
bin count: 6
3%: Opening com.。.
Invalid response!
BUILD.gn
deps = [
“os:liteos_glue”,
deps += [
“ohosdemo:ohosdemo”
deps += [
group(“xr806”) {
举报
