电子元器件论坛
直播中
电子工程师
20年用户 16601经验值
擅长:可编程逻辑 模拟技术 测量仪表 控制/MCU RF/无线 MEMS/传感技术
私信 关注
诠鼎集团力推MPS提供车用高能源效率解决方案
`MPS(Monolithic Power System)推出汽车照明系统、TFT BIAS、功放系统解决方案。这些方案为各种汽车应用提供超高能源效率,特别适用于车厢照明灯、显示器背光灯、转向信号灯、刹车灯以及车头灯。
■ 符合AEC-Q100标准产品
■ 系统解决方案
■ 高效率
1. MPS Power Solution: CD/DVD/Navigation
■ MPQ4560:55V, 2A Buck Converter
FEATURES
- Guaranteed Industrial Temp Range Limits.
- Wide 4.5V to 55V Operating input Range.
- 250mΩ Internal Power MOSFET
- Up to 2MHz Programmable Switching Frequency.
- 120μA Quiescent Current
- Ceramic Capacitor Stable
- Internal Soft-Start
- Up to 95% Efficiency
- Output adjustable from 0.8V to 52V
- Available in 3x3mm 10-Pin QFN and SOIC8 Packages with Exposed pads
- AEC-Q100 Qualified in SOIC8 Package.
Highlight :
- 55V voltage rating
- AEC-Q100 qualified
■MP2495: 100V Surge, 2A Buck Converter
FEATURES
- Replaces External Transorb
- Input Surge Protection Up to 100V
- Programmable up to 2.0A Output Current
- Output Adjustable from 0.8V to 15V
- Programmable Output Current Limit without power loss
- 0.25Ω Internal Power MOSFET Switch
- Stable with Low ESR Output Ceramic Capacitors
- 95% Efficiency ﹫500mA(Vo=5V)
- Fixed 700KHz Frequency
- Themal Shutdown
- Cycle-by-Cycle Over current Protection
- Available in a 16-Pin SOIC Package
Highlight :
- 100V rating. 80V/100mS surge input voltage duration
- High eficiency
- Programmable Output Current Limitation
■ MP2016 : 42V, 30mA LDO
FEATURES
- 4V to 42V Input Range
- 12μA Quiescent supply Current
- <1.5μA shutdown Current
- 1.2V to 24V adjustable Output
- 30mA Output Current with 50mA Peak Current Limit
- +-2% Accuracy
- Thermal Shutdown
- Available in Tiny TSOT23-5 and QFN-8 Packages
Highlight :
- 42V voltage rating
- Small size
- In queue for AEC-Q100 qualification
■ MP1530 : Triple Output for TFT Bias Supply
FEATURES
- 2.7 to 5.5V Operating Input Range
- 2.8A Switch Current Limit
- 3 Outputs In a Single Package
1. Step-Up Converter up to 22V
2. Positive 20mA Linear Regulator
3. Negative 20mA Linear Regulator
- 250mΩ Internal Power MOSFET Switch
- 1.4MHz Fixed Frequency
- Internal Power-On Sequencing
- Adjustable Soft-Start/Fault Timer
- Cycle-by-Cycle Over Current Protection
- Under Voltage Lockout
- Ready Flag
- 16-Pin, QFN(3mm x 3mm) or TSSOP Packages
Highlight :
- High Efficiency
- Small Solution Size
Supply typical Application Circuit
回帖(1)
qian
2011-6-8 15:30:21
呵呵。。。进来学习下。。。
我公司瑞隆源自主设计、制造、销售以及提供客户个性化产品解决方案。产品的涉及范围广泛,包括静电保护元件、瞬变抑制二极管、玻璃放电管、陶瓷气体放电管和半导体放电管、压敏电阻、自恢复保险丝。我们一直在发展一种独特的商业模式,包括专有技术平台和能够满足高规格防雷过流过压保护元件,来提高产品保护性能,增强产品应用环境的灵活性和产品的可扩展性。
  通过自主研发,我们已开发出了7大系列可直接销售的产品。公司设在中国深圳,以此为基地依靠我们自身的资源制造过压过流元件,除此之外,我们垂直整合的业务模式使我们的生产技术解决方案满足客户需求。
我们相信应用广泛的产品、垂直整合的业务模式使我们极具竞争优势。客户包括遍布世界的电信和数据通信网络系统供应商及其合同制造商,由于在产品设计和开发时期就紧跟客户,确保及时响应客户批量生产的需求。
我们的宗旨是:作过流过压元件性价比最好的厂商,让你用最少的付出获取最大的效益。
详情请咨询:0755-82908296
举报
更多回帖
