完美!有时最简单的解决方案是最难找到的......我应该想到这个!谢谢斯科特莫里森-----原始信息-----来自:Michael A***ery [mailto:Michael.A***ery@nrl.navy
发送时间:2002年10月16日星期三下午12点57分:'MORRISON,SCOTT(A-Sonoma,ex1)';
'VEE vrf'Subject:RE:[vrf] Unbuild coord试试这个,我仍然使用'unbuild coord'对象,但是它们被埋没在用户函数中,可以在公式中调用.Mike -----原始消息---
- 来自:MORRISON,SCOTT(A-Sonoma,ex1)[mailto:scott_morrison@agilent.com]发送时间:2002年10月15日星期二下午3:47到:VEE vrfSubject:[vrf] Unbuild coordAnybody在那里知道如何解建
没有使用'UnbuildCoord'对象的坐标?
我需要在公式中访问彼此独立的坐标,而不将它们分开到公式对象之外。
是这样的东西:unbuildx(),如果传递一个像'( - 1,1)'这样的坐标会返回'-1'?目前我唯一的解决方案是通过asText语句解析数据并通过asReal语句返回值,但是
这样做似乎非常残忍。我错过了什么?TIAScott ---您目前订阅了vrf:r***@soco.agilent.com要订阅,请发送一封空白电子邮件至“join-vrf@it.lists.it。
agilent.com“。要取消订阅,请发送空白电子邮件至”leave-vrf@it.lists.it.agilent.com“。要发送邮件到此邮件列表,请发送电子邮件至”vrf@it.lists.it.agilent.com“
如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。
以上来自于谷歌翻译
以下为原文
Perfect!
Sometimes the easiest solution is the hardest to find....I should have thought of that!
Thanks
Scott Morrison
-----Original Message-----
From: Michael A***ery [mailto:Michael.A***ery@nrl.navy.mil]
Sent: Wednesday, October 16, 2002 12:57 PM
To: 'MORRISON,SCOTT (A-Sonoma,ex1)'; 'VEE vrf'
Subject: RE: [vrf] Unbuild coord
Try this, I still use the 'unbuild coord' object, but they are buried in
user functions which can be called in a formula.
Mike
From: MORRISON,SCOTT (A-Sonoma,ex1) [mailto:scott_morrison@agilent.com]
Sent: Tuesday, October 15, 2002 3:47 PM
To: VEE vrf
Subject: [vrf] Unbuild coord
Anybody out there know how to unbuild a coord without using the 'Unbuild
Coord' object? I need to access the coordinates independant of each other
in a formula without splitting them up outside the formula object. Is there
something like:
unbuildx() which would return '-1' if passed a coord like '(-1,1)'?
Currently my only solution is to parse the data through an asText statement
and return the value through an asReal statement, but this seems pretty
brutal to do a lot of.
Am I missing something?
TIA
Scott
You are currently subscribed to vrf as: [email=r***@soco.agilent.com]r***@soco.agilent.com[/email]
To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".
To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".
To send messages to this mailing list, email "vrf@it.lists.it.agilent.com".
If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".
以上来自于谷歌翻译
以下为原文
Perfect!
Thanks
Scott Morrison
Mike
To: VEE vrf
something like:
TIA
Scott
举报
