我建议在PLTS中使用PNA Cal模式(这意味着PNA控制测试集而不是PLTS PC)。
这将要求您在PNA上有选项550(4端口校准)。
启用PNA校准模式后,PNA显示为本机4端口分析器,本机PNA SCPI或COM编程接口完全支持此功能。
您可以使用PNA的命令来完成一个完整的1-4端口ecal。
如果可能的话,当PNA校准模式可用时,我几乎不建议在PLTS中使用传统校准模式。
PNA校准模式提供了更大的灵活性,校准可以在PNA独立设置为激活。
以上来自于谷歌翻译
以下为原文
I would recommend using PNA Cal mode with PLTS (this does mean that the PNA is controlling the test set and not the PLTS PC). This would require that you have option 550 on the PNA (4 port calibration). With PNA cal mode enabled, the PNA appears as a native 4 port analyzer and the native PNA SCPI or COM programming interface is fully support for this. You can use the PNA's commands to complete a full 1-4 port ecal.
If possible, I hardly ever recommend using legacy calibration mode in PLTS when PNA cal mode is available. PNA cal mode offers quite a bit more flexibility and the calibrations can be set to active on the PNA standalone.
以上来自于谷歌翻译
以下为原文
举报
