module paobiao(CLK,CLR,PAUSE,MSH,MSL,SH,SL,MH,ML); //端口说明
input CLK,CLR;
input PAUSE;
output[3:0] MSH,MSL,SH,SL,MH,ML; //内部信号说明
reg[3:0] MSH,MSL,SH,SL,MH,ML;
reg cn1,cn2; //cn1为百分秒向秒的进位,cn2为秒向分的进位
//百分秒计数模块,每计满100,cn1 产生一个进位
always @(posedge CLK or posedge CLR) begin
if(CLR) begin //异步复位
{MSH,MSL}<=8'h00;
cn1<=0;
end
else if(!PAUSE) begin //PAUSE 为0时正常计数,为1时暂停计数
if(MSL==9) begin
MSL<=0; //低位计数至10时,低位归零
if(MSH==9) begin
MSH<=0; //低、高位计数至10时,高位归零
cn1<=1; //低、高位计数至10时,触发进位位
end
else //低位计数至10,高位计数未至10时,高位计数
MSH<=MSH+1;
end
else begin
MSL<=MSL+1; //低位计数未至10时,低位计数
cn1<=0; //低位计数未至10时,不触发进位位
end
end
end
//秒计数模块,每计满60,cn2 产生一个进位
always @(posedge cn1 or posedge CLR) begin
{SH,SL}<=8'h00;
cn2<=0;
end
else if(SL==9) begin
if(SH==5) begin
SH<=0; //低位计数至10,高位计数至6时,高位归零
cn2<=1; //低位计数至10,高位计数至6时,触发进位位
end
else
SH<=SH+1; //低位计数至10,高位计未数至6时,高位计数
end
else begin
SL<=SL+1; //低位计数未至10时,低位计数
cn2<=0; //低位计数未至10时,不触发进位位
end
end
//分钟计数模块,每计满60,系统自动清零
always @(posedge cn2 or posedge CLR) begin
{MH,ML}<=8'h00;
end
else if(ML==9) begin
ML<=0; //低位计数至10时,低位归零
if(MH==5)
MH<=0; //低位计数至10,高位计数至6时,高位归零
else
MH<=MH+1; //低位计数至10,高位计未数至6时,高位计数
end
else
ML<=ML+1; //低位计数未至10时,低位计数
end
endmodule
input CLK,CLR;
input PAUSE;
{MSH,MSL}<=8'h00;
cn1<=0;
end
if(MSL==9) begin
if(MSH==9) begin
end
MSH<=MSH+1;
end
else begin
end
end
end
{SH,SL}<=8'h00;
cn2<=0;
end
if(SH==5) begin
end
else
end
else begin
end
end
{MH,ML}<=8'h00;
end
if(MH==5)
else
end
else
end
endmodule
