我刚买了一台HP11713A ATTENUATOR / SWITCH DRIVER和2个可编程步进衰减器(8494H和8496H)我可以使用直接i / o并发送那些字符串如“A12B5678”并让衰减器垫打开/关闭。问:是
有一个仪器驱动程序,这样你就可以发送一个十进制数,如63,并将重点配置为63dB?-dan k.san diegoDan K.'92 Gray Dak CC,318,4x2,46RH,3.55后,
235 / 75R15,PS,PW,PB,PL,AC。模式:冷空气,K& N油/空气,180 * T-Stat,Autolite 3924s,重新定位IAT,Trans-Go换档套件。未来:交换电机
对于略微修改的Magnum 5.9L引擎.
以上来自于谷歌翻译
以下为原文
I just got a HP11713A ATTENUATOR/SWITCH DRIVER and 2 programmable step attenuators (
8494H and 8496H )
I can use direct i/o and send those strings of charactors such as "A12B5678" and get the
attenuator
pads to switch on/off.
Q: Is there an instrument driver for this so that you can send a decimal number, like
63, and have the attenuoator re-configured for 63dB?
-dan k.
san diego
Dan K.
'92 Grey Dak CC, 318, 4x2, 46RH, 3.55 rear, 235/75R15, PS, PW, PB, PL, AC.
Mods: Cool air, K&N oil/air, 180* T-Stat, Autolite 3924s, re-located IAT, Trans-Go shift kit.
Future: Swap motor for a slightly modified Magnum 5.9L engine.
