是德科技
直播中
夏涌革
7年用户 170经验值
私信 关注
[问答]
如何修复HP 83631B服务支持软件
大家好。
我们有HP 83631B(它实际上是HP 8510C VNA系统的一部分),它昨天出现了问题。
作为修复它的第一步,我们尝试使用服务支持软件并进行调整。
不幸的是,伴随源的两个磁盘以及我们的备份集都已损坏。
我试图在这里找到软件,但我无法在任何地方找到它。
有人可以帮我吗?
在此先感谢... GeorgeEdited:gkrik于2012年4月24日上午2:52
以上来自于谷歌翻译
     以下为原文
  Hi to all.
We have an HP 83631B (it is actually part of an HP 8510C VNA system) which has yesterday showed a problem. As a first step in order to fix it we are trying to use the service support software and do the adjustments. Unfortunately the two disks accompanying the source, as well as our backup set, are damaged. I tried to locate the software here, but I can't find it anywhere. Could anyone please help me with that? Thanks in advance...
George
Edited by: gkrik on Apr 24, 2012 2:52 AM
回帖(3)
夏涌革
2019-8-7 08:39:12
嗯,实际上我做到了!
我最初在源组中发布。
但是你(我的意思是来自管理员的人)已将它移到这里。
以上来自于谷歌翻译
     以下为原文
  Well, actually I did! I originally have posted in the sources group. But you (I mean someone from the administrators) have moved it here.
举报
陈建华
2019-8-7 08:48:55
引用: zoujishi15 发表于 2019-8-7 08:39
嗯,实际上我做到了!
我最初在源组中发布。
嗯,无论管理员做了什么,可能都不知道这是一个来源,因为你在第一篇文章中提到过VNA,我可以看出这可能会被误解。
我不知道如何处理这个问题,以免同样的错误再次发生。
也许你可以在源组中再次发布它,但不要提及VNA。
同时,我会看看我是否可以联系合适的人来处理这篇文章。
以上来自于谷歌翻译
     以下为原文
  Hmmm, whatever admin did that probably did not know this was a source, and since you mentioned VNA in your first post, I can see how that could be misconstrued.  I am not sure how to deal with this so that the same mistake does not happen again.  Maybe you can post it again in the sources group, but do NOT mention VNA.
Meanwhile, I will see if I can contact the proper person about handling this post.
举报
夏涌革
2019-8-7 08:57:03
好的,我会再次发布,就像你提到的那样。
以上来自于谷歌翻译
     以下为原文
  OK, I will post it there again, the way you mention.
举报
更多回帖
