引用: 脑洞大赛9 发表于 2019-7-26 18:24
我们生产的产品(并且已经存在多年)确实可以用于各种材料测量。
它被称为材料测量软件!
链接在这里:http://cp.literature.agilent.com/litweb/pdf/5988-9472EN.pdf;
嗨!
我是呼叫中心的应用工程师,我支持8507x系列软件。
自2001年以来,8720B分析仪已经过时,没有任何支持,因此我对85071支持8720系列分析仪的大部分知识必须从内存中调用。
在85071E版本的E.04和E.05软件中有8720系列的传统支持。
我不记得确切支持8720的哪个特定版本(有8720B型号,8720C,8720D,8720ES / ET是最后一个版本)。
您+可能+能够获得该软件的“Legacy”E.05版本,以便通过GPIB与8720B进行通信,因为872x系列通信驱动程序已经保留。但是,*没有*保证功能,我们将无法
在呼叫中心支持此设置。
我无法验证它是否可行,因为我不再有8720B坐在我身后的联络中心进行测试。
您可以从以下网站下载该软件:8507x系列:软件下载页面。
该软件附带*免费* 2周试用许可证。
购买之前试一试!
在页面的右侧,靠近底部,您将看到一个标题为“Legacy Analyzers”的框,您可以在此下载85071E软件的旧版本(修订版85071E.05.01.21)。
值得注意的是,该软件的旧版本(修订版85071E.05.01.21)将不会更新。
试用85071E的旧版本,使用GPIB与8720B进行通信,看看它是否适合你。编辑:MarkH于2012年8月8日下午5:50
以上来自于谷歌翻译
以下为原文
Hi! I am an application engineer at the call center and I support the 8507x family of software.
The 8720B analyzer has been obsolete with no support since 2001, as a result much of my knowledge of the 85071 support the 8720 series of analyzers has to be recalled from memory.
There was legacy support for the 8720 family in the 85071E version E.04 and E.05 software. I do not remember exactly which specific versions of the 8720 were supported (there was an 8720B model, an 8720C, an 8720D, and the 8720ES/ET was the last version).
You +might+ be able to get the "Legacy" E.05 version of the software to communicate with the 8720B over GPIB since the 872x family communication drivers were left in. However, there is *no* guarantee of functionality and we will be unable to support this setup at the call center. I cannot verify if it will work or not because I no longer have an 8720B sitting in behind me in the contact center to test with.
You can download the software from this website:
8507x Series: Software Downloads Page. The software comes with a *free* 2 week trial license. Try it out before you buy!
Off to the right hand side of the page, near the bottom, you will see a box titled "Legacy Analyzers", here you can download the legacy release of the 85071E software (revision 85071E.05.01.21). It is worth noting that that the legacy version of the software (revision 85071E.05.01.21) will not be updated.
Try out the legacy version of the 85071E out using GPIB to communicate with the 8720B and see if it works for you.
Edited by: MarkH on Aug 8, 2012 5:50 PM
它被称为材料测量软件!
嗨!
在呼叫中心支持此设置。
该软件附带*免费* 2周试用许可证。
购买之前试一试!
以上来自于谷歌翻译
以下为原文
举报
