赛灵思
直播中
李艳婷
8年用户 246经验值
私信 关注
[问答]
无法在极光的接收器上得到软信号该怎么办?
我发送了正确的帧信号(带有软件)到极光,但我无法在极光的接收器上得到软信号(eof和src信号正确)。
我该怎么办?
要删除数据?
以上来自于谷歌翻译
以下为原文
I sent the right frame signal (with the sof eof) to the aurora,but I can't get the sof signal (the eof and src signal right)on the receiver of aurora sometime. what should I do? To drop the data?
回帖(3)
王山崎
2019-7-23 14:17:03
核心配置是什么?
发布.xco文件供参考。你是否在simulation.Regards,Krishna上看到了这个问题
---------------------------------------------请将帖子标记为
如果提供的信息能够回答您的问题/解决您的问题,请“接受为解决方案”。给予您认为有用的帖子。
以上来自于谷歌翻译
以下为原文
What is the core configuration? Post .xco file for reference.
Are you seeing this issue on simulation.
Regards,
Krishna-----------------------------------------------------------------------------------------------
Please mark the post as "Accept as solution" if the information provided answers your query/resolves your issue.
Give Kudos to a post which you think is helpful.
举报
贾佳斌
2019-7-23 14:36:50
你发送了多少帧?
如果您发送多个帧并且没有为它们显示SOF,我希望得到frame_err断言。
是这样的吗?
----------------------------别忘了回复,给予kudo并接受为解决方案---------
以上来自于谷歌翻译
以下为原文
How many frames are you sending? If you are sending more than one frame and SOF does not appear for them, I expect to get frame_err asserted. Is this the case?------------------------------------------------------------------------------
Don't forget to reply, give kudo and accept as solution
举报
贾佳斌
2019-7-23 14:48:13
确认您遵循协议要求以在模拟中传输帧。
以上来自于谷歌翻译
以下为原文
Confirm that you are following the protocol requirements to transfer the frames in simulation.------------------------------------------------------------------------------
举报
更多回帖
