嗨,尝试使用最新工具运行设计,即ISE 14.7如果问题仍然存在,请在此处发布您的设计。谢谢
------------------------------------------您是否尝试在Google中输入问题?
如果没有,你应该在发布之前。
此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。
以上来自于谷歌翻译
以下为原文
Hi,
Try running the design in latest tools i.e., ISE 14.7
If the issue still occurs, post your design here.
Thanks--------------------------------------------------------------------------------------------
Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution.
如果没有,你应该在发布之前。
以上来自于谷歌翻译
以下为原文
Hi,
举报
