校准后更换电缆肯定会导致不匹配问题。
还有其他变量(例如环境 - 温度和湿度以及物理 - 电缆弯曲)会影响校准有效的时间长度。
我个人也认为ENA使用的默认70 kHz IFBW太宽,通常将其降至3 kHz或以下。
您还需要注意校准后添加到系统中的其他适配器(或校准后移除),因为它们会导致不匹配条件发生变化,从而影响校准。
您可以考虑发布一些您正在看到的内容以及设置中正在发生变化的屏幕截图。
以上来自于谷歌翻译
以下为原文
Changing cables after a calibration can definitely cause mismatch issues. There are other variables (such as environmental - temperature and humidity and physical - cable flexure) that can effect the length of time that a calibration is valid. I personally, also think that the default 70 kHz IFBW that the ENA uses is too wide and usually drop it down to or below 3 kHz. You would also want to be careful with an additional adapters that are added to the system after calibration (or removed after calibration) as they can cause the mismatch conditions to change which will affect the calibration.
You might consider posting a couple screenshots of what you are seeing as well as what is changing in the setup.
校准后更换电缆肯定会导致不匹配问题。
以上来自于谷歌翻译
以下为原文
举报
