lalobegar wrote:Your question make no sense. The four quadrature DCM outputs are supposed to be used inside the FPGA.
Hi,
I want to generate 4 clock signal with different phase (0,90,180,270). I know this can be done with a DCM, but I want to use those clock signals for other processes inside the FPGA, it is possible to do that?
Regards.
举报
举报
lalobegar wrote:First of all, you don't need to generate all four phases, because you can use the falling edge of a clock to clock a flip-flop just as well as using the rising edge.
Ok thanks! Now I can generate a 400MHz clock with a 200MHz clock, and after that, can I use this 400MHz clock as an input to another DCM and generate the four clock signals I mentioned before?
举报
举报
更多回帖
