你还能订购这部分,还是-5(更快)速度等级的相同部分?
我相信两者的答案都是'是'。
器件系列之间没有引脚兼容性(Spartan-3 vs. Spartan-3a vs. Spartan-3e vs. Spartan-6)。
如果您有兴趣选择可以购买多年的零件,那么请考虑一个最近的器件系列中的非引脚兼容器件。
如果您有兴趣维护当前的FPGA设计和电路板,那么请购买您当前使用的FPGA,或者购买相同器件的更快速度等级。
您也可以咨询Xilinx销售代表以获取指导。
- 鲍勃埃尔金德
签名:新手的自述文件在这里:http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369总结:1。
阅读手册或用户指南。
你读过手册了吗?
你能找到手册吗?2。
搜索论坛(并搜索网页)以寻找类似的主题。
不要在多个论坛上发布相同的问题。
不要在别人的主题上发布新主题或问题,开始新的主题!5。
学生:复制代码与学习设计不同.6“它不起作用”不是一个可以回答的问题。
提供有用的详细信息(请与网页,数据表链接).7。
您的代码中的评论不需要支付额外费用。
我没有支付论坛帖子的费用。
如果我写一篇好文章,那么我一无所获。
在原帖中查看解决方案
以上来自于谷歌翻译
以下为原文
Can you still order this part, or the same part in the -5 (faster) speed grade? I believe the answer to both is 'YES'.
There is no pin-compatibility across device families (Spartan-3 vs. Spartan-3a vs. Spartan-3e vs. Spartan-6).
If you are interested in selecting a part which can be purchased for many years to follow, then consider non-pin-compatible devices in one of the more recent device families. If you are interested in maintaining the current FPGA design and circuit boards, then purchase the FPGA you are currently using, or a faster speed grade of the same device.
You can also consult your Xilinx sales rep for guidance.
-- Bob Elkind
SIGNATURE:
README for newbies is here: http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369
Summary:
1. Read the manual or user guide. Have you read the manual? Can you find the manual?
2. Search the forums (and search the web) for similar topics.
3. Do not post the same question on multiple forums.
4. Do not post a new topic or question on someone else's thread, start a new thread!
5. Students: Copying code is not the same as learning to design.
6 "It does not work" is not a question which can be answered. Provide useful details (with webpage, datasheet links, please).
7. You are not charged extra fees for comments in your code.
8. I am not paid for forum posts. If I write a good post, then I have been good for nothing.View solution in original post
我相信两者的答案都是'是'。
- 鲍勃埃尔金德
阅读手册或用户指南。
你读过手册了吗?
你能找到手册吗?2。
不要在多个论坛上发布相同的问题。
您的代码中的评论不需要支付额外费用。
我没有支付论坛帖子的费用。
如果我写一篇好文章,那么我一无所获。
在原帖中查看解决方案
以上来自于谷歌翻译
以下为原文
-- Bob Elkind
SIGNATURE:
Summary:
举报
