ST意法半导体
直播中
张家旺
7年用户 187经验值
私信 关注
[问答]
请问怎么才能通过负触发电路连接SMPS来控制TRIAC?
你好
我想直接从MCU(STM32F0)控制ST的无缓冲三端双向可控硅开关(T435-800)。根据AN3168(第2.4条),我要将AC主(220V,50Hz)电源与控制电路的Vdd连接起来。在AN392中,我发现用负电源说明三端双向可控硅开关控制,但使用电容式滴管。实际上,在连接AC主电源和+ 5V DC之后,我不明白发生了什么。所有我想和AN392一样,但想要使用SMPS(STEVAL-ISA010V1,基于Viper16)。或者我还需要其他东西,比如二极管剪刀吗?
感谢您。
#triac #smps
以上来自于谷歌翻译
以下为原文
Hello
I want to control ST's snubberless triac (T435-800) directly from MCU (STM32F0). According to AN3168 (article 2.4), I've to connect AC main (220V, 50Hz) supply with the control circuit's Vdd. In AN392, I found the same that illustrate triac control with negative power supply, but uses capacitive dropper. Actually, I didn't understand what's going on there after connecting AC main with +5V DC.? All I want to do the same as AN392, but wants to use SMPS (STEVAL-ISA010V1, based on Viper16).  or Do I need anything else such as diode clipper?
Thanking you.
#triac #smps
回帖(1)
张家旺
2019-6-24 08:31:29
好吧,AN4564解释了我所需要的一切。
以上来自于谷歌翻译
以下为原文
All right, AN4564 explained all I need.
举报
更多回帖
