VEE 9开发
可以在Windows7上安装env和I / O Lib 15.1。
这需要几个技巧但我没有看到任何问题,因为我开始使用VEE / Windows7 Beta1.Key的事情是将.msi文件设置为兼容模式(右键单击/属性)。
对于VEE 9,这很简单,解压缩并转到Develop文件夹并将Agilent VEE Pro.msi文件设置为兼容模式。
然后运行Setup.exe(在同一文件夹中).I / O Lib 15.1解压缩到隐藏的AppData / Local / Temp文件夹中的几个文件夹。
我建议尽可能从Temp文件夹中删除,解压缩并在错误转到新文件夹后将.msi文件设置为兼容模式。
然后运行Setup.exe(在同一文件夹中找到)VEE 9据我所知,无法安装运行时。
它还解压缩到Temp文件夹,但脚本会删除错误之后的所有文件,因此.msi文件不能(?)设置为兼容模式。
但是,可以使用Windows7新的XP模式功能安装VEE运行时!
以上来自于谷歌翻译
以下为原文
VEE 9 dev. env and I/O Lib 15.1 can be installed on Windows7. It takes couple of tricks but I have not seen any problems since I started to use VEE/Windows7 Beta1.
Key thing is to set the .msi file to compatibility mode (right click/Properties). For VEE 9 this is easy, unzip and goto Develop folder and set the Agilent VEE Pro.msi file to compatibility mode. Then run Setup.exe (in same folder).
I/O Lib 15.1 unzips to a couple of folders in your hidden AppData/Local/Temp folder. I recommend deleting as much as possible from the Temp folder, unzip and after the error goto the new folders and set the .msi files to compatibility mode. Then run Setup.exe (found in same folder)
VEE 9 Run-time is not possible to install as far as I know. It also unzips to the Temp folder but the script deletes all files aftre the error so the .msi file cannot(?) be set to compatibility mode. However, VEE Run-time can be installed using Windows7 new XP mode feature!
VEE 9开发
以上来自于谷歌翻译
以下为原文
举报
