ST意法半导体
直播中
廖漳彩
7年用户 186经验值
私信 关注
[问答]
请问LSM6DSL和LSM6DS3的兼容性如何?
我们正在考虑在新设计中使用LSM6DS3,但我注意到LSM6DSL使用了一半的功率。这两个部分看起来是引脚兼容的,可能与软件兼容(至少对于大多数功能而言)。那是对的吗?
更具体地说:使用AN4650应用笔记与LSM6DSL一起使用是否有效(至少在该部分有类似的应用笔记可用之前)?如果部件与LSM6DSL交换,是否可能为LSM6DS3编写的代码有效?
有关LSM6DSL的使用申请说明的任何ETA?
#lsm6ds3#lsm6dsl
以上来自于谷歌翻译
以下为原文
We were looking at using the LSM6DS3 in a new design, but I noticed the LSM6DSL uses half the power.  The two parts look to be pin compatible and probably software compatible (at least for most features).  Is that correct?
More specifically: is it valid to use the AN4650 Application note to work with the LSM6DSL (at least until there is a similar application note for that part available)?  Is it likely that code written for LSM6DS3 would work if the part were swapped with the LSM6DSL?
Any ETA on a usage application note for the LSM6DSL?
#lsm6ds3 #lsm6dsl
回帖(1)
周芳卿
2019-6-12 11:12:14
你好贾森,
我绝对可以推荐你使用
 即使LSM6DS3与LSM6DSL非常相似,我建议你参考应用笔记(
http://www.st.com/content/st_com/en/products/mems-and-sensors/inemo-inertial-modules/lsm6dsm.html
 )因为它几乎相同,。您还可以比较(http://www.st.com/content/st_com/en/products/embedded-software/mcus-embedded-software/stm32-embedded-software/stm32cube-expansion中的LSM6DS3-LSM6DSL编码差异。 -software / x立方体-mems1.html
 )或(http://www.st.com/content/st_com/en/products/embedded-software/mcus-embedded-software/stm32-embedded-software/stm32cube-expansion-software/x-cube-mems-xt1 html的
 )SW软件包,您可以从ST网站免费下载。这些封装支持几个Nucleo板和MEMS Shield板(IKS01A1和IKS01A2)。
感谢你并致以真诚的问候,
切赫
以上来自于谷歌翻译
以下为原文
Hello Jason,
I can definitely recommend you to use
Even if LSM6DS3 is very similar to LSM6DSL, I suggest you to refer to  application note (
) since it is almost the same, . Also you can compare the LSM6DS3-LSM6DSL coding differences in the  (http://www.st.com/content/st_com/en/products/embedded-software/mcus-embedded-software/stm32-embedded-software/stm32cube-expansion-software/x-cube-mems1.html
) or  (http://www.st.com/content/st_com/en/products/embedded-software/mcus-embedded-software/stm32-embedded-software/stm32cube-expansion-software/x-cube-mems-xt1.html
) SW packages which you can download from ST web for free. These packages support a few Nucleo boards and MEMS Shield boards (IKS01A1 and IKS01A2).
Thank you and best regards,
Petr
举报
更多回帖
