Microchip
直播中
段丽
7年用户 162经验值
私信 关注
[问答]
ICD3出错了
大家好,我的ICD3有个奇怪的问题。就在一个星期前,它停止工作了。我做的第一件事是用AC164113模块对程序员进行自我检查,报告了一个问题:所以,我打开了客户支持的票来解决这个问题。他们转向SAR并给我一个替代品,今天收到了。首先,我把它插进去,猜猜怎么回事,用同样的错误信息仍然是错误的。所以,我尝试了一个不同的USB电缆,没有用。-尝试用MPLAB-X 3.51空白检查两个干净的PIC16F818:返回ID错误(0)。在PIC16F818上用MPLAB-X IPE尝试同样的事情:与ABO相同。在不同的PC上移动和重复上面的所有内容:没有变化。-在同一台不同的PC上,用MPLAB 8重试:没有改变。OS是两个PC上的Windows 7 X64。尝试重新安装Java和MPLAB-X,这两个版本都是不同的版本。实际上我没有选择。我希望这里的人能知道发生了什么事,我等待客户支持的答复。
以上来自于百度翻译
      以下为原文
    Hello everyone.
I've got a weird problem with my ICD3. Just out of the blue, a week ago it stopped working. First thing I did was to self-check the programmer with the AC164113 module, which reported a problem:
Test interface PGC clock line write failure. Please ensure that the tester is properly connected.
Test interface PGD data line write not tested.
Test interface PGC clock line read not tested.
Test interface PGD data line read not tested.
Test interface LVP control line not tested.
Test interface MCLR level not tested.
Interface test could not be completed. Please contact your local FAE/CAE to SAR the unit.
So, I opened a ticket with customer support to solve the issue. They turned to SAR and sent me a replacement, received today. First thing, I plug it in and, guess what, still faulty with the same error message.
So, I:
- Tried with a different USB cable, to no avail.
- Tried blank checking a couple of clean PIC16F818 with MPLAB-X 3.51: returned ID error (0).
- Tried the same thing on the PIC16F818 with MPLAB-X IPE: same as above.
- Move and repeat all of the above on a different PC: no change.
- On the same different PC, retry all with MPLAB 8: no change.
OS is Windows 7 x64 on both PC. Tried reinstalling Java and MPLAB-X, different versions of both.
I'm actually out of options. I hope someone here may have an idea of what's going on, while I wait for an answer from customer support.
Thanks in advance
Paul
回帖(5)
李志强
2019-5-15 14:50:13
进一步的信息:尝试用XP在VM上安装MPLAB-X新安装。同样的结果,测试失败…
以上来自于百度翻译
      以下为原文
    Further info: tried a MPLAB-X fresh install on a VM with XP. Same result, test failed... sad:
举报
张蕾
2019-5-15 15:04:43
HiDID更换了一个新的目标电缆(短的一个6P6C连接器)?我会开始在那里寻找问题。
以上来自于百度翻译
      以下为原文
    Hi
Did the replacement come with a new target cable (the short one with the 6P6C connectors)?
I would start looking for the problem there.
Best regards
Jorge
举报
李志强
2019-5-15 15:14:38
不,我在用旧的,但是我用RJ电缆检查器测试了,看起来还行。
以上来自于百度翻译
      以下为原文
No, I'm using the old one, but I tested it with a RJ cable checker and seems ok...
举报
杨叶
2019-5-15 15:23:48
您好,你们有没有原始的微芯片板(已知的工作板)?如果你有一个替代品,它不工作,这是一个很可能的工具不是问题…所以接下来要检查的是应用板和PC安装(尝试安装MPLAB X在另一台PC上)。
以上来自于百度翻译
      以下为原文
    Hi,
Do you have any original Microchip board (Known to Work board) ?
If you get a replacement and it does not work there is a very probability that the tool is not the issue...
So next thing to check is the application board and the PC installation (try install MPLAB X on another PC).
Regards
举报
更多回帖
