是德科技
直播中
李淑兰
8年用户 199经验值
私信 关注
[问答]
怎么通过Excel编程N5765A
您好,我目前正在尝试使用VBA通过Excel 2010控制我的N5765A。
我对VBA很新,但我能够相当容易地使用DMM。
我的问题在于我不知道任何合适的语法,以告诉源使用什么电压/电流值。
我花了一段时间在互联网上搜索,试图获得一个VBA语法列表,但这种结果毫无结果。
任何帮助将不胜感激!谢谢,迈克
以上来自于谷歌翻译
     以下为原文
  Hello,
I'm currently trying to control my N5765A through Excel 2010 with VBA. I'm pretty new to VBA but I am able to utilize DMMs fairly easily. My issue lies in that I know none of the appropriate syntax in order to tell the source what voltage/current values to use. I spent a while scouring the internet to try and get a list of VBA syntax but that came up fruitless. Any help would be greatly appreciated!
Thanks,
Mike
回帖(1)
罗敏
2019-4-28 12:07:24
嗨Mike,我们在网上有一些N5700耗材的示例程序,包括Excel。
您可以在以下位置找到示例:[http://www.home.agilent.com/agilent/editorial.jspx?cc=US&lc=eng&ckey=514495&nid=-35688.384869&id=514495]。
这些程序使用Agilent VISA IO库。
我还附上了我写的N6700 MPS示例,该示例使用的是Agilent VISA-COM,我认为它比VISA更好一点,更容易使用。
两者之间的命令不同,但您可以在N6700示例中看到如何编程。
以上来自于谷歌翻译
     以下为原文
  Hi Mike,
We do have some example programs for the N5700 supplies on the web, including Excel.  You can find the examples at:
[http://www.home.agilent.com/agilent/editorial.jspx?cc=US&lc=eng&ckey=514495&nid=-35688.384869&id=514495].
These programs use the Agilent VISA IO library.
I have also attached a N6700 MPS example that I wrote that uses Agilent VISA-COM which I think reads a bit better and is a little easier to use than VISA.  The commands are different between the two but you can see how to program in the N6700 example.
附件
举报
更多回帖
