Microchip
直播中
周振夜
7年用户 209经验值
私信 关注
[问答]
IPECMD无法找到JRE
Heloon是一个没有安装MPLAX的计算机,在运行IPECMD时,我“找不到JRE”。我试图建立一个测试夹具,并使用ICD3来编程板,因为他们的生产。我如何解决这个问题?谢谢您!
以上来自于百度翻译
      以下为原文
    Hello
On a computer that does not have MPLab X installed, I get "unable to find jre" when running ipecmd.  I am attempting to setup a test fixture and use the ICD3 to program the boards as they are produced.  How can I resolve this issue?
Thank you!
回帖(4)
李天竹
2019-4-22 08:40:07
你需要安装IPE。它与安装MPLAB X相同,但是安装时选择“IPE”,而不是“IDE”。这就产生了更小的安装。我在我的电脑上有这个功能,我也注意到,如果你打开了IPE应用程序,IPECMD,由于某种原因,工作得更快。
以上来自于百度翻译
      以下为原文
    You need to install IPE. It is the same as installing MPLAB X, but when installing you select "IPE", but not "IDE". This produces a smaller install. I have this on my computer and it works.
I also noticed that if you have IPE application open, IPECMD, for some reason, works faster.
举报
李玉兰
2019-4-22 08:47:51
谢谢帮忙!但是,我找不到程序员。我可以通过MPLAB IPE连接到程序员。它更新了固件。但是,当我从命令行运行时,我没有程序员。我的命令行是:我从MPLab安装的目录运行这个命令。
以上来自于百度翻译
      以下为原文
    Thanks that helped!  However, I am getting programmer not found.  I can connect to the programmer via MPLab IPE.  It updated its firmware.  However, when I run from the command line, I get programmer not found.
my command line is:
ipecmd -P18F45K20 -M -Y -Fc:MyHex.hex
I run this from the directory where MPLab installed it.
举报
李玉兰
2019-4-22 08:58:32
以上来自于百度翻译
      以下为原文
my command line is:
举报
李玉兰
2019-4-22 09:17:05
我现在开始工作了。我把IPECMD转换成ICD3CMD,它成功地编程了我的设备并验证了HEX。
以上来自于百度翻译
      以下为原文
    I have it working now.  I changed ipecmd to icd3cmd and it programmed my device successfully and verified the hex.
举报
更多回帖
