Cypress技术论坛
直播中
王秀芳
8年用户 180经验值
私信 关注
[问答]
是否可以使用两个IDAC创建一个恒定电流双相脉冲来刺激生物组织
我很好奇,我是否可以使用两个IDAC创建一个恒定电流双相脉冲来刺激生物组织。我不完全理解IDAC电压合格和它如何与我的项目。我想得到的总持续时间1毫秒100微安的脉冲,并将负载为MegaOhms。
有人评论IDAC电压合格,如果我的负载电流的要求可能使用IDAC。
以上来自于百度翻译
     以下为原文
  I'm curious as to whether I could use two iDAC to create a constant current biphasic pulse to stimulate biological tissue. I don't completely understand the iDAC compliance voltage and how it would relate to my project. I would like to produce a 100 microAmp pulse with a total duration of 1 ms, and the load will be 0.5-1.0 MegaOhms.
    Cound someone comment on the iDAC compliance voltage, and if my load and current requirements would be possible using the iDAC.
回帖(1)
王淑珍
2019-4-15 14:19:44
100uA到1MOHM意味着100V越过整个路程。不要认为你可以直接使用PSoC IDAC。你需要有外部电路来做这件事。
以上来自于百度翻译
     以下为原文
  100uA into 1Mohm means 100V across the load. Don't think you can use the pSoC IDAC directly. you need to have external circuitry to do this.
举报
更多回帖
