赛灵思
直播中
孙宇
7年用户 145经验值
私信 关注
[问答]
怎么在ILA调试模式下看到显示信号的幅度?
大家好
如果我想在ILA调试模式下看到显示信号的幅度怎么办?
你觉得有可能在屏幕上看到吗?
例如,我在附加的图片上标记了红色箭头和蓝色箭头。
你认为我可以调整信号的幅度吗?
(如示波器)
或调整ILA显示的水平(范围)?
例如增加放大范围(ILA中的刻度/电平限制),这样我就可以看到更小尺寸的三角形信号。
或者减小幅度范围,这样我可以看到三角形信号的较大尺寸,或者由幅度配置设置(蓝色箭头)切割的三角形。
简单地说,是否有任何其他选项或配置设置用于ILA调试,如示波器?
我将不胜感激任何评论或帮助
谢谢
以上来自于谷歌翻译
以下为原文
Hi all experts
What if I want to see the amplitude of the displayed signal on ILA Debug mode,
do you think it is possible to see on the screen?
For example, I marked red arrow and blue arrow on the attached pic,.
Do you think I can adjust thet amplitude of the signal? (like oscilloscope)
or adjust the level (range) of ILA display?
such as increasing the range of amplidtude (scale/level limit in ILA), so that I can see smaller size of triangle signal.
or decreasing the range of amplitude, so that I can see bigger size fo triangle signal, or the trignale which is cut by the level of amplitude configuration setting (blue arrow).
simply, is there any other option or configuration setting for ILA debug such as oscilloscope?
I will appreciate any comment or help
Thank you
回帖(3)
王文霞
2019-4-11 08:47:36
嗨,要查看在波形窗口中查看ILA探测数据时可以完成的所有自定义,请参阅以下UG章节10http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_3/ug908-vivado-programming-debugging
.pdf -Shreyas
--------------------------------------------尝试搜索你的答案
在发布新帖子之前在论坛或xilinx用户指南中发出问题。请注意 - 如果提供的信息解决了您的问题,请将答案标记为“接受为解决方案”。给予您认为有用的帖子给予荣誉(右边提供的星号)
并回复.----------------------------------------------
在原帖中查看解决方案
以上来自于谷歌翻译
以下为原文
Hi,
To see all the customization that can be done while viewing ILA probe data in waveform window, please see following UG chapter 10
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_3/ug908-vivado-programming-debugging.pdf
-Shreyas----------------------------------------------------------------------------------------------
Try to search answer for your issue in forums or xilinx user guides before you post a new thread.
Kindly note- Please mark the Answer as "Accept as solution" if information provided solves your query.
Give Kudos (star provided in right) to a post which you think is helpful and reply oriented.
----------------------------------------------------------------------------------------------View solution in original post
举报
王文霞
2019-4-11 09:02:06
.pdf -Shreyas
以上来自于谷歌翻译
以下为原文
Hi,
举报
励黎
2019-4-11 09:11:45
谢谢@ aher
在第10章中查看模拟波形正是我所寻找的。
以上来自于谷歌翻译
以下为原文
Thank you @aher
Viewing Analog Waveforms in chapter 10 was exactly what I was looking for.
举报
更多回帖
