嗨@ bbinb,
检查您的FSM是否使用异步复位,如果FSM具有异步复位,则无法使用Block RAM实现。
有关ISE中FSM编码样式的更多信息/示例,请参阅以下用户指南
http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/xst.pdf
--Syed
--------------------------------------------请注意 - 请注明
答案为“接受为解决方案”,如果提供的信息是有帮助的。给予您认为有用的帖子。感谢 -
-------------------------------------------请注意 - 请标记答案
如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------
以上来自于谷歌翻译
以下为原文
Hi @bbinb,
Check if your FSM is using asynchronous reset as if FSM has an asynchronous reset, it cannot be implemented using block RAM.
You can refer to following user guide for more information/example FSM coding styles in ISE
--Syed
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.
Give Kudos to a post which you think is helpful.
Give Kudos to a post which you think is helpful and reply oriented.
嗨@ bbinb,
--Syed
以上来自于谷歌翻译
以下为原文
Hi @bbinb,
--Syed
举报
