我想知道如何擦掉一个坏的固件下载到它?我使用CY368(CY7C68033的EVM)进行测试,显然使用NANDMFG下载了一个Bug固件。现在,我不能再使用NANDFG来编程它了,因为设备不能被NandMfg识别,尽管可以被其他CyPress实用程序识别,比如CySudio。我想知道是否有任何工具来清除闪存芯片?[注:EVM是可以的,因为如果挂上闪存芯片,我仍然可以正常访问它]谢谢。
以上来自于百度翻译
以下为原文
I wonder how to erase a flash with bad firmware downloaded to it? I am using CY3686 (CY7c68033's EVM) for tes
ting; and obviously downloaded a buggy firmware to it using NandMfg. Now, I can no longer program it using NandMfg because the device is not recognizable by NandMfg, although can be recognized by the other Cypress utility like CyConsole. I wonder if there is any tools to erase the flash chip? [note: the EVM is ok because if I changed the flash chip i can still access it normally] Thanks in advance.
