是德科技
直播中
李春梅
8年用户 1984经验值
私信 关注
[问答]
怎么从Agilent DMM Connectivity Utility将数据日志导入BenchVue
使用BenchVue Data Manager,您可以导入先前从Agilent DMM Connectivity Utility软件存储的数据日志。
从BenchVue中的数据管理器表单击“导入数据日志”按钮,导航到包含Connectivity Utility软件中数据日志的所需位置。
默认情况下,数据日志存储在Connectivity Utility软件的以下目录中:C: Users \ Documents  Agilent  Agilent Digital Multimeter Connectivity Utility  DataLogs 如果数据日志位于本地计算机上的文件夹中,则为BenchVue
将在“数据管理器”列表中添加对该文件夹的引用。
如果数据日志位于网络驱动器或外部硬盘驱动器上,BenchVue会将数据日志复制到本地计算机上“仪器专用”文件夹中的“我的文档”文件夹中。
例如 - C: Users \ Documents  Agilent  BenchVue  Digital Multimeter  Data Logs 。
复制数据日志文件夹后,BenchVue将在“数据管理器”列表中添加对该文件夹的引用。
根据存储数据日志的大小,导入操作可能需要一些时间才能完成。
以上来自于谷歌翻译
     以下为原文
  Using the BenchVue Data Manager, you can import data logs previously stored from the Agilent DMM Connectivity Utility software. From the Data Manager sheet in BenchVue, click the "Import Data Logs" button to navigate to the desired location containing the data log from the Connectivity Utility software. By default, data logs are stored in the following directory from the Connectivity Utility software:
C:Users\DocumentsAgilentAgilent Digital Multimeter Connectivity UtilityDataLogs
If the data log is located in a folder on your local computer, BenchVue will add a reference to that folder in the Data Manager list.
If the data log is located on a network drive or an external hard drive, BenchVue will copy the data log to the "My Documents" folder on your local computer, in instrument-specific folders. For example – C:Users\DocumentsAgilentBenchVueDigital MultimeterData Logs. Once the data log folder is copied, BenchVue will add a reference to that folder in the Data Manager list.
Depending on the size of the stored data log, an import operation could take some time to complete.
附件
回帖(1)
林立银
2019-3-4 13:11:38
嗨daveh,
我无法将文件(csv)导入DMM。
我可以把你的文件发给你然后你可以查看它是否正确吗?
提前致谢。
埃尔韦
以上来自于谷歌翻译
     以下为原文
  Hi daveh,
I'm not able to import file(csv) into DMM.
Could I send you  my File then you can check if its correct?
Thanks in advance.
Hervé
举报
更多回帖
